| c.m.c problem? | |
+6jh3xp Fairladysx_s13 D*S Dstar D*S Roski Nachtmensch RAD MIKE Circa 3006 10 posters |
| Subject: c.m.c problem? October 11th 2008, 11:55 pm | |
| ok so llast couple of weeks my clutch pedal has been feeling soft at first and not pop back up but then if i gave it a few pumps or drove it a little it would feel fine and come back up no problem. but now it wont feel fine anymore just like shit and i can barely get it in gear with it like this. is this my clutch master cylinder or maybe my pushrod?
please help! | |
| Subject: Re: c.m.c problem? October 12th 2008, 12:05 am | |
| sounds clutch master cylinder. replace that and flush the fluid | |
D*S Roski DS! DS! DS!
| Subject: Re: c.m.c problem? October 12th 2008, 9:18 am | |
| Subject: Re: c.m.c problem? October 12th 2008, 9:23 am | |
| Slave. Bet 5 on it. Easy as cake. Ill type a walkthrough. If needed. For max entry. | |
| Subject: Re: c.m.c problem? October 12th 2008, 9:33 am | |
| i hope its the slave just because its cheaper and you should type a walkthrough because i know the location but dont know where to go after there. thanks! | |
| Subject: Re: c.m.c problem? October 12th 2008, 9:38 am | |
| Subject: Re: c.m.c problem? October 12th 2008, 9:42 am | |
Fairladysx_s13 Light Duty Poster
Number of posts : 147 Age : 33 Location : Chi Vehicle : 89 Hatch Sr Reputation : 0
| Subject: Re: c.m.c problem? October 12th 2008, 2:25 pm | |
| i kno its not slave... had this problem for a while but still havent fixed it. Ive put 2 new ones in and changed nothing besides the fact of the older ones leaking. Im pretty sure its a internal leak in the clutch master cylinder. Id say do both... theres a package thing on ebay for both including a new line too for a lil over a hundo. | |
| Subject: Re: c.m.c problem? October 12th 2008, 2:28 pm | |
| Just because it wasnt the slave in your case doesnt mean its not the slave in his case. Ive had that shit happen on a bunch of s13's ive driven. Each time its been the slave. | |
jh3xp Forum Frequenter
Number of posts : 312 Age : 33 Location : Hoffman Estates, IL Vehicle : 92 240sx coupe Reputation : 1
| Subject: Re: c.m.c problem? October 12th 2008, 2:35 pm | |
| Just replace both slave and master since theyre both only like 30 dollars and bound to go out sometime anyways. Get a SS line to delete the damper box too and make sure you bleed it well. | |
| Subject: Re: c.m.c problem? October 12th 2008, 2:38 pm | |
| thats why im saying both... it could be either. but when slaves go they dont last long after they start leaking. thts all im saying... | |
| Subject: Re: c.m.c problem? October 12th 2008, 4:17 pm | |
| - jh3xp wrote:
- Get a SS line to delete the damper box.
more info please! | |
| Subject: Re: c.m.c problem? October 12th 2008, 4:46 pm | |
| Go to nico tech article section. They have a detailed walkthrough. Its super simple. You just take out the stupid clutch damper and run a SS line or bend the stock hardline into your slave soft line. I did it on my car and roski's car also I believe. | |
| Subject: Re: c.m.c problem? October 12th 2008, 5:32 pm | |
| - Fairladysx_s13 wrote:
- but when slaves go they dont last long after they start leaking. thts all im saying...
not really .. i'd find my clutch pedal down to the floor like once a week when my slave was going out. . then .. while the dstar was dailying it .. it took a complete shit. . lucky me. . | |
| Subject: Re: c.m.c problem? October 13th 2008, 12:17 am | |
| i dont think i have one cuz my car was swapped to manual. im gonna order a new slave tomorrow. | |
| Subject: Re: c.m.c problem? October 15th 2008, 3:14 pm | |
| ok why do people use brake fluid as opposed to clutch fluid? | |
| Subject: Re: c.m.c problem? October 15th 2008, 3:29 pm | |
| - Mike wrote:
- i dont think i have one cuz my car was swapped to manual.
im gonna order a new slave tomorrow. .. you dont think you have one? have one what? and i agree with edgar.. ive had 5 240s.. and every single one of them had a clutch master or slave problem.. 9/10 you will have a bad slave..its a 10 dollar fix. | |
| Subject: Re: c.m.c problem? October 15th 2008, 3:42 pm | |
| ok i dont have a damper thing and i order my slave and gonna pick it up later tonight and install tomorrow and hope for the best.
but again does it matter if i use clutch fluid instead of brake fluid? | |
| Subject: Re: c.m.c problem? October 15th 2008, 3:58 pm | |
| theyre made of the same thing on 240's. as long as its rated dot 3... and go ahead and try the slave.. but if it doesnt work then u kno its clutch master cylinder for sure. | |
| Subject: Re: c.m.c problem? October 16th 2008, 11:46 am | |
| with my luck i am missing my 14mm wrench which is need to get the soft line off. sweeet | |
| Subject: Re: c.m.c problem? October 17th 2008, 2:48 pm | |
| ok i stripped the bolt to get the soft line off. i quit. | |
| Subject: Re: c.m.c problem? October 17th 2008, 4:03 pm | |
| how badly is it stripped?
Did you make sure to soak the shit out of it with pb blaster or nuts off before you attempted to loosen it? | |
| Subject: Re: c.m.c problem? October 17th 2008, 9:17 pm | |
| umm fuck no. who soaks shit?!
and it isnt that bad stripped | |
| Subject: Re: c.m.c problem? October 18th 2008, 12:25 am | |
| - Mike wrote:
- umm fuck no.
who soaks shit?!
and it isnt that bad stripped if you want to reduce the chance of stripping/shearing/snapping/etc. you should atleast spray some of that shit on the nuts/bolts/etc. | |
| Subject: Re: c.m.c problem? October 18th 2008, 9:58 am | |
| soaking the nuts is the only way to make sure its fully lubricated and reduces the amount of friction making it easier to take off. | |
| Subject: Re: c.m.c problem? | |
| c.m.c problem? | |
