 i got a problem
5 posters
Number of posts : 1310
i got a problem Empty
PostSubject: i got a problem   i got a problem Icon_minitimeJuly 23rd 2009, 12:19 am
Ok so swapped my old ka out back in may might have lost a few trans bolts. Ever since then my trans/clutch grinds when I push the clutch down mostly in 1st and reverse after so long of that. About 3 weeks ago I str8 broke my clutch will post pics later its cool.
Replaced clutch throw out bearing resurfaced flywheel new slave and master even got a new trans with no grinds.
During the breaking in process it starts making that grindin noise again some times it worse something it doesn't do it. Like I said makes that noise and don't let me get in gear when I push the clutch down or it does but sounds Like ass, 1st and reverse usually do it sometimes all gears 4th is doing it too. Its getting gay cause sounds Like idk how to drive when I try driving it. Oh and we might of lost more trans bolts maybe that may cause the issue idk I mean its on there good. Anyone have any ideas or anything let me know plz.
Number of posts : 593
PostSubject: Re: i got a problem   i got a problem Icon_minitimeJuly 23rd 2009, 2:15 am
If I wasn't so busy this week, I'd help you out. But how in the world do you lose trans bolts? Note to self, keep your work area organized, place bolts in clear marked baggies next time. If anything, I have an old service manual for an 89 240sx that you can borrow.
PostSubject: Re: i got a problem   i got a problem Icon_minitimeJuly 23rd 2009, 2:19 am
sounds like your clutch line isnt bled properly OR your pedal isnt adjusted
i can almost gurantee its one of those two things
Number of posts : 259
Vehicle : 1995 240sx Se
PostSubject: Re: i got a problem   i got a problem Icon_minitimeJuly 23rd 2009, 9:58 am
What trans bolts are you talking about? I may have what your missing.
Number of posts : 969
PostSubject: Re: i got a problem   i got a problem Icon_minitimeJuly 24th 2009, 11:20 am
you might also want check your flux capacitor too while your at
i got a problem
» c.m.c problem?
» S13 powersteering problem.
» Houston We Have a problem ^_^
» timing problem
» Fuel Cut Problem!
