| idling problem | |
mikemadison_09 Forum Frequenter
Number of posts : 267 Age : 32 Location : chicago Vehicle : 89 coupe Reputation : 0
| Subject: idling problem September 19th 2008, 1:36 pm | |
| the car idles at the normal idle then drops to like 400 then idles itself up to like 1200 to 1500 then i give a little gas and goes back to normal and it just keeps doing it what could it be? | |
djexpo Forum Frequenter
Number of posts : 452 Age : 35 Location : Chicago Vehicle : 89 240sx Coupe Reputation : -1
| Subject: Re: idling problem September 19th 2008, 2:04 pm | |
| does it almost die out and does it happen wen you slow down and come to stops? | |
| Subject: Re: idling problem September 19th 2008, 2:10 pm | |
| sometimes when i hit the brakes it drops to like 100 so maybe a vacum line? but it dosent do that all the time | |
| Subject: Re: idling problem September 19th 2008, 2:13 pm | |
| yea same here man..my vacuum lines are all niggerrigged. did this just start happenin tho? | |
| Subject: Re: idling problem September 19th 2008, 2:15 pm | |
| yeah after i changed out an injector it ran good for a day and then this started happening | |
| Subject: Re: idling problem September 19th 2008, 3:10 pm | |
| yea i doubt it was the injector. didnt u tell me ur whole motor was fucked? | |
| Subject: Re: idling problem September 20th 2008, 11:40 am | |
aklothingco Fucking Noob
Number of posts : 9 Age : 37 Location : Champaign, IL Vehicle : 95' S14.5 Reputation : 0
| Subject: Re: idling problem September 20th 2008, 2:17 pm | |
| Do your brakes feel abnormal? There is a check valve at the brake booster, when they go bad it creates a bad vacuum leak. Check the valve, make sure it only allows air in one direction, a quick check would be to plug the vacuum to the booster and see if it changes anything. Vacuum issues are a pain to find, it would be worth taking it to a shop with a smoke tester. A smoke tester will show you every leak in a few minutes, eliminating a lot of headache. | |
| Subject: Re: idling problem September 20th 2008, 2:18 pm | |
| Also, what engine is it? Do you have any kind of intake? Stock ECU? | |
| Subject: Re: idling problem September 22nd 2008, 1:58 pm | |
| ka24de with a injen intake and stock ecu | |
| Subject: Re: idling problem September 22nd 2008, 1:59 pm | |
| it drop to like 100rpm but it doesnt do it everytime just every once in a while | |
drifterxxl180 Fucking Noob
Number of posts : 34 Age : 41 Location : South Holland Vehicle : 95 240sx Reputation : 0
| Subject: Re: idling problem September 23rd 2008, 2:04 am | |
| get some carb cleaner spray around the intake manifold if there is a leak through there you should notice the rpms raise. I had a problem similar to this with my s14 turns out it was a vacuum leak and bad intake manifold gasket after the maf causing a fucked up idle upon taking the upper intake manifold off all the hoses were cracked and leaking | |
spinner Light Duty Poster
Number of posts : 121 Age : 82 Location : Schaumburg Vehicle : 95 S14, 05 Evo RS Reputation : 0
| Subject: Re: idling problem October 3rd 2008, 12:01 pm | |
| idle controller? went bed? check your intake, for leaks or cracks. | |
| Subject: Re: idling problem | |
| idling problem | |
