 clutch help
Number of posts : 306
Vehicle : Sr'd hatch
clutch help Empty
PostSubject: clutch help   clutch help Icon_minitimeJuly 25th 2007, 5:04 pm
so im finishing up my motor swap and the last thing i have to do before cranking is "pressureizeing the clutch" ?
1st] is that the right term "pressureizeing the clutch"
2nd] how do i do it?
my friend told me its like bleeding out the brakes. where i put in some fluid then seal off the system and press on the clutch and keep going til theres no more air. but i dont know if thats right.
so can anyone help?
http://www.myspace.com/ninjasaurusrex
toky042
Number of posts : 163
Vehicle : 92 hatch/89 coupe
clutch help Empty
PostSubject: Re: clutch help   clutch help Icon_minitimeJuly 25th 2007, 5:35 pm
bleed the clutch, have a friend help u, pump the clutch pedal 3 times, hold the clutch in fully on 3rd time, ur friend under the car releasin the fluid from the clutch slave cylinder n tighten the nipple, repeat process until air bubbles r out
clutch help Empty
PostSubject: Re: clutch help   clutch help Icon_minitimeJuly 26th 2007, 1:52 pm
what kind of fluid should i use, and what kind do you recomend?
Berzerker
Number of posts : 194
clutch help Empty
PostSubject: Re: clutch help   clutch help Icon_minitimeJuly 26th 2007, 3:29 pm
Dot 3 Brake fluid....
clutch help Empty
clutch help
» new clutch?G.M.C?plz help!
» new clutch...what to get?
» My clutch issue
» WTB s14 clutch
» WTB sr clutch
