lopezjrslide Fucking Noob
Number of posts : 32 Age : 40 Location : des plaines Vehicle : 92 240sx se Reputation : 0
| Subject: new clutch?G.M.C?plz help! April 13th 2007, 7:00 pm | |
| ok six months ago my clutch was slipping i changed the clutch and the slave cylinder and grand master cylinder on my 92 240sx.afterwards it was slipping so i took it back and they sais that they adjusted something. so then i got it back the next day and it was running good. i drove it for 6 months and all i used the car for was work and back. so a week ago i got inside the car in the morning and then i pushed the clutch pedal down and it wouldnt come up. so i checked the slave cylinder and it was leaking, so i bleed the clutch it still woulnt come back up .so i changed it wich was 3 days ago and once we did that we checked the clutch and it was completely worn out.so we changed it. 2 days ago it stared slipping again. is there sumting i need to adjust on the gran master cylinder or slave cylinder? or the clutch pedal after changing a clutch on a 240?now i got a new grand master cylinder,slave cylinder and a new clutch and its still slipping crazy that i cant even drive it. | |
| Subject: Re: new clutch?G.M.C?plz help! April 13th 2007, 8:44 pm | |
| Sounds like it might be your clutch fork, seeing as how youve changed everything else. Check the pedal adjustment also, im an expert at diagnosing clutch problems now..hahha. | |
| Subject: Re: new clutch?G.M.C?plz help! April 14th 2007, 10:12 am | |
| ^Lol!
Did you do all the work yourself? Is the dampening box still attached? Did you make the proper adjustments? Did you have the flywheel machined? New or used clutch disc? How long before the old clutch disk went out? | |
| Subject: Re: new clutch?G.M.C?plz help! April 14th 2007, 3:32 pm | |
| - Rated240R wrote:
- ^Lol!
Did you do all the work yourself? Is the dampening box still attached? Did you make the proper adjustments? Did you have the flywheel machined? New or used clutch disc? How long before the old clutch disk went out? exactly. it could be a number of things. we need more info. i changed everything too. my clutch went fast because the flywheel was cut wrong. | |
| Subject: Re: new clutch?G.M.C?plz help! | |
