 Removing Emissions problem Kade
5 posters
Removing Emissions problem Kade Empty
PostSubject: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 30th 2013, 3:01 am
I took out my charcoal canister and all the vacuum hoses.. I capped the 2 hoses under the throttle body with rubber caps, and the skinny hard line and the hose under the canister. Car starts, but won't hold idle.. Like it dies out right after.. Thoughts? I re- installed the emissions shit and car runs fine.. How can i remove that shit and run?? Btw kade
PostSubject: Re: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 30th 2013, 3:41 am
Apparently from what I've read, the pressure builds up in the tank so it has a hard time idling. Might just need to find a way to vent the fuel fumes that build up pressure. I read somewhere that if you have less fuel it'll run, but if you have a full tank or whatever it'll have a hard time with idle. Idk though, I haven't done it because I'm stuck with the damn thing for emission testing... even though some sensor or whatever is fucked anyway
Number of posts : 3100
PostSubject: Re: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 30th 2013, 6:30 am
Pretty sure you are suppose to loop one of those vacuum lines. Ill snap a picture of my shit later. Ill text it to you sirs. Been meaning to hit you back up. Haha.
PostSubject: Re: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 30th 2013, 1:16 pm
Pics please
PostSubject: Re: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 30th 2013, 1:29 pm
dont cap the hard line that goes back to the tank, leave it open. That is a vent for the fumes, pressure will build in tank if you cap that.
PostSubject: Re: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 30th 2013, 7:06 pm
I looped mine on my Miata. Should work the same for a 240.
PostSubject: Re: Removing Emissions problem Kade   Removing Emissions problem Kade Icon_minitimeMarch 31st 2013, 2:57 pm
Got it running all good thanks to Ds Dave.. Good looking homie
» Removing Oil Feed Line SR20DET Redtop
» 96 with motorwork done, will it pass emissions?
» WTB: KAE or KADE
» s13 kade no ecu power
» SR/KADE Swap issues?
