Number of posts : 27 Age : 37 Location : chicago Vehicle : s14 Reputation : -1
Subject: rerouting the wiring on a s14 June 15th 2011, 12:49 am
does anybody have any idea of how to this. rerouting the wiring harness inside the engine bay any websites or advice will be helpful. its for my 95 S14 i need to to this so i could lower the car more.
mishkin_707 Forum Frequenter
Subject: Re: rerouting the wiring on a s14 June 15th 2011, 3:28 am
take off the fender zip tie it higher. done.
Subject: Re: rerouting the wiring on a s14 June 15th 2011, 11:54 am
theres a point where the tire will still touch the harness where it comes thru the firewall-ish area. which then must be moved to the bay. i had it done the long way, because i zip tied it up, then rubbed thru about 10 wires, then we just cut each 1 by 1 and moved it about the wheel well and wired it back up.
that's the long way. should be writeups somehwere.
Subject: Re: rerouting the wiring on a s14 June 15th 2011, 1:53 pm
nice^ i didn't think about that.
whiterps13 Post Enthusiast
Number of posts : 1385 Age : 36 Location : Rockford Vehicle : S4 Reputation : 11
Subject: Re: rerouting the wiring on a s14 June 15th 2011, 2:03 pm
OR just make a sheet metal shield and screw that shit right over the spot that the tire rubs the harness. It will still rub, but that way you dont have to worry about it eating through wires. Easy way.
Subject: Re: rerouting the wiring on a s14 June 15th 2011, 10:14 pm
then just worry about it eating the tire more. then loosing more life on the tire for when you want to flip the tire over.
just re-route it to the bay, if ur gona cut it, do it one by one, cutting is NOT rec. for doing this. mine was already torn to pieces as well as my hood latch cable. which is the only reason i did it.
Bullet Fucking Noob
Subject: Re: rerouting the wiring on a s14 June 16th 2011, 6:18 am
@FusionR300zx hey got any pictures of were you put your harness in the bay and the hood latch cable? another question me and my friend were thinking about making plugs so then i could plug it after cutting it you think its a good idea or might it cause trouble? the plugs are heavy duty there the ones you find on trucks and other sort of heavy vehicles they could withstand heat and weather.
Subject: Re: rerouting the wiring on a s14 June 16th 2011, 10:33 am
ehh I did that on my s13 at one point and it got hooooot. Melted the harness.
To the OP I did it to my s14, its tedious you can do it a couple ways. -you can take the dash out and find the big major plug, pull that. (honestly its a pain) but that way you dont have to cut any wires.
-If you take your time you can lengthen some of your wires and run it through the frame of your car. I think it looks better. and then you dont run the risk of rubbing through anything. Just take each wire and do it one by one.
Either way you do it, dont route the harness through the original hole in the firewall because it would defeat the reason for rerouting it.
Subject: Re: rerouting the wiring on a s14 June 17th 2011, 1:58 am
connector plugs would be cool OP, go to the junk yard and get some oem connector plugs from a cars chassis
Subject: Re: rerouting the wiring on a s14 June 17th 2011, 9:22 am
plugs would be ok as long as u wire up the connection to the female/male connectors. i have no pics of where i put it, but i run it between the fender and strut tower are on the inside of the engine bay.. i'll see if i have any pics of my engine bay after it was done, but i don't think i took any ever.
Bullet Fucking Noob
Subject: Re: rerouting the wiring on a s14 June 27th 2011, 2:31 pm
well i tried the plugs and failed because i did not have the correct tool to crimp them. so i went the other route of soldering the wires one by one the and i extended the wires about 6 inches each so i could have some slack to play with ,whole project was about a five hour job but it was worth the effort and i got allot of soldering practice too!!! check out the pics . this is how it looked before. this is when i solder the wires . this is how all the wires looked after i was done really messy. after i cleaned the wires up a bit put new wire loom/wrap some of the tools i used wire cutter, fishing knife, needle nose pliers, radio shack soldering iron . i wasted about 60 bucks in materials it would have been less but i did not have the soldering iron so i went out and got it. cutting and soldering is not recommended but it worked for me this was also my first time soldering wires together so i you tubed a soldering lesson that's what i used and it worked for me i here is the link
