| Skater Steves s13. Just picked it up. | |
+10koh_ki240 hs13kls Nachtmensch Adrian_S13 Jay rcl1221 Xmax D*S Roski D*S Dstar Scuba Steve 14 posters |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 6:51 am | |
| Yeah, most real drift cars run aftermarket Tension rods, tie rods, rucas, toe rods, traction arms...but not aftermarket Lca's and roll center adjustment kits and shit like that. Not really necessary for the average or even pro drifter. Drift cars arent usually THAT dialed in. | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 10:03 am | |
| shit is using washers!!!! No bueno! Also the double adjustable shit might loosen on one side, hell it may even get disconnected from the rod end. Not to mention introducing second point of failure. Also wonder if the treads are opposite or same, as with one you won't be able to adjust the arms without taking one off the spindle, which is going to SUCK! Hard to say without actually having it in my hand or speaking with someone who knows anything about them.
FYI there are 3dolla rod ends and there are 35dolla rod ends. Circle track boys know that shit needs to be replaced twice a season. I wonder if they just have a straight toe arm or do they have a bend in it to accommodate the dropped Schassis (see SPL v2 toe arms)
Wait, did he WELD the bolts to the bracket???
Ahh, fuck it, I don't care. Run them if you want. But just out of curiosity how much are you paying for them (tension rod/ruca/whatever)? | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 11:38 am | |
| - Jay wrote:
- shit is using washers!!!! No bueno!
Also the double adjustable shit might loosen on one side, hell it may even get disconnected from the rod end. Not to mention introducing second point of failure. Also wonder if the treads are opposite or same, as with one you won't be able to adjust the arms without taking one off the spindle, which is going to SUCK! Hard to say without actually having it in my hand or speaking with someone who knows anything about them. the double adjustable ones have opposite threading so that when both ends are stationary, you twist the center portion one direction to lengthen it, and then ose the locking nuts to secure it in place. | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 12:11 pm | |
| yeah, i noticed that it might be (all arms are that way) thats why I asked if the bolt was welded to the bracket. But why use washers? | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 1:36 pm | |
Scuba Steve Established Member
Number of posts : 551 Age : 35 Location : I don't know. It's really dark in here! Vehicle : '93 S13 with all the Fanboy features! Reputation : -7
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 10:36 pm | |
| Not sure about prices. And I'm not sure that they are what I am going to run.
If I go with something else, what are some good brands of suspension parts out there? Cause I'm still not sure whats good, bad, or otherwise. | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 10:43 pm | |
| spl and dmax are good from what i hear
Rated240R can get you a deal on the megan racing links. I'm running those right now. People on the internet keep saying that the links are bad and whatnot, but so far no problems for me. | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 11:03 pm | |
| SPLParts (Kuah) and BattleVersion/OrangeTree (Alex put cheaper rod ends on the OT so that cheap 240 owners can still get good arms)
I've also heard good things about PeakPerformance (except tie rods)
Megan - I've blew through 2 sets of tie rod ends in short time. Decided that was enough not to run any other suspension parts, as they use same cheap rod ends.
In the end you get what you pay for. | |
| Subject: Re: Skater Steves s13. Just picked it up. April 1st 2008, 11:24 pm | |
| - Jay wrote:
Megan - I've blew through 2 sets of tie rod ends in short time. Decided that was enough not to run any other suspension parts, as they use same cheap rod ends. yea, the megan tie ends are horrible from what I've seen, but havent seen many bad stuff about the other parts besides 1 pic of a ruca not having a full weld on one side. | |
shiftin_sideways Light Duty Poster
Number of posts : 118 Age : 38 Reputation : 1
| Subject: Re: Skater Steves s13. Just picked it up. April 8th 2008, 8:37 pm | |
Last edited by shiftin_sideways on April 8th 2008, 9:08 pm; edited 1 time in total | |
| Subject: Re: Skater Steves s13. Just picked it up. April 8th 2008, 8:39 pm | |
definitely get the ES master bushing kit. That was my first upgrade when i got my car. Its a bitch to do, but its good to do | |
| Subject: Re: Skater Steves s13. Just picked it up. April 8th 2008, 11:05 pm | |
| Would it be so hard if the engine was out? | |
| Subject: Re: Skater Steves s13. Just picked it up. April 8th 2008, 11:20 pm | |
| Subject: Re: Skater Steves s13. Just picked it up. April 9th 2008, 10:32 am | |
| subframe and arms should be easy because he has a non-hicas subframe out of the car. and the arms he has to swap over anyway. should be fairly simple with the work that has to be done anyway. | |
| Subject: Re: Skater Steves s13. Just picked it up. April 9th 2008, 11:01 am | |
| ^ i forgot he has a subframe out of the car. That will be really easy then | |
| Subject: Re: Skater Steves s13. Just picked it up. | |
