 slave cylinder problem?
toky042
7 posters
toky042
Number of posts : 163
Vehicle : 92 hatch/89 coupe
slave cylinder problem? Empty
PostSubject: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 4:56 pm
i just got brand new slave cyl, i tightened it around the end of the boot with a clamp thingy which when u tighten the screw it tightens, but when i bleed it now, the WHOLE boot fills up and looks like a filled up condom with water about to explode. Can anyone help me with my problem, my dd is takin a **** on me right now
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 4:59 pm
sounds like the piston that pushed the rod isnt sealing.
go get another one. this one is defective.
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 5:01 pm
werd
and what did you tighten exactly? pics?
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 5:06 pm
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 5:16 pm
i dont think you are suppose to clamp and tighten that part
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 5:22 pm
if i didnt clamp it, i would pop off like the other 3, so any suggestions would be great
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 5:52 pm
werd
who are you buying these slave cylinders from? i had an autozone one on my old s13 and had no problems like what youre having.
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 5:56 pm
did it fill up like a balloon and pop off when its bolted on and pressing against the fork?
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 6:37 pm
yeappppp, tats y i clamped so it wouldnt, but obviously the fork pushed all the way out anywayz. btw the clamp idea was from somone on another forum
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 6:45 pm
but this been happening to me for the past 4 slaves Sad
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 7:46 pm
Nope. No need for a clamp. I changed Roskis slave last week with an
Autozone one and after i bled it properly its been working beautiful.
Number of posts : 1053
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 11:41 pm
yea...i just pushed mine in there...deff..not good if its filling with fluid..
assuming you have a warentee on it..get a new one
(i know....i cant spell)
http://www.leagueltd.com
Number of posts : 1608
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 12th 2008, 11:44 pm
Maybe they gave you the same one 3 times.
Take it back and tell them they are fired.
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 13th 2008, 5:01 pm
but in all seriousness, if you show us actual pics of how it looks when installed and what it is doing with clutch not pressed and pressed, then we can help you better.
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 14th 2008, 6:29 am
well, it is the same brand i guess
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 14th 2008, 10:12 pm
i was wrong, i dont think its the slave since i just got another slave thats original and it still does the same. Im leaning towards the master cylinder, anyone help?
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 14th 2008, 11:39 pm
walk us through how you are bleeding the clutch line.
i think i know the problem.
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 14th 2008, 11:48 pm
basically pump the clutch 3 times, 3rd time hold, release, tighten screw, repeat
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 15th 2008, 12:05 am
ok, just to make sure; you have the slave bolted to the trans and the rod in the fork right? if not, youre blowing the cylinder out everytime.
get any pics for us?
you dont have the clutch damper on there anymore right? if so, remove it.
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 15th 2008, 12:45 pm
i dont got the clutch damper, its straight line to the slave, and the slave is bolted up corrently n the rod in the fork but nackers told me it might be a clutch pivot problem
Number of posts : 1394
Vehicle : '91
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 15th 2008, 12:53 pm
Nackers is correct in thinking the pivot ball. It the piston is comin out to far then there is no resistance or stop for the piston. Either the pivot ball is fucked up, or the clutch fork.
Only way to tell is to drop the trans.
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 17th 2008, 11:36 pm
I win!
Anyway, whats the update on that situation. I missed hella COD4 workin with you on that problem so I deserve some closure.
toky042
PostSubject: Re: slave cylinder problem?   slave cylinder problem? Icon_minitimeMarch 18th 2008, 12:29 am
ha, fixin it tomorow or sometime this week
» sr only gets spark on 1st cylinder
» Door Lock Cylinder
» timing problem
» S13 powersteering problem.
» c.m.c problem?
