| one of those wtf problems... | |
| Subject: one of those wtf problems... August 20th 2007, 9:32 pm | |
| alright here's the laydown, i'm going to start from the begining
i swapped heads on my KA24DE motor in my '92 [ish] 240sx
now for whatever reason cyl #2 refuses to fire
here's what i've tried
swapping plugs from cyl to cyl swapping injectors from cyl to cyl buying new [well used] injectors and swapping those in testing wires for spark leak
now here's the thing
when using a NOID light i get a pulse on that cyl when hooking up a spare injector to the dead cyl harness it clicks when the injector is supposed to fire there is spark in the dead cyl... that's not the issue
when hooking up a DVOM to the injector harness on all the other cyl's besides the dead one there is 13.7 volts on one lead and 0 on the other... however on the dead one there is 13.7 volts on one lead and 12.4~12.2 volts on the other lead...
when holding a piece of paper over the cyl with the plug out there is no gas collected
what the bloody fuck is wrong with my car???
it was running fine until the swap | |
| Subject: Re: one of those wtf problems... August 20th 2007, 10:09 pm | |
| VERY weird. i'm assuming you cleaned/inspected all the connections. try swapping injectors again...... thats the only thing i can think of. unless you fried something in the harness or ecu. | |
profpin Light Duty Poster
Number of posts : 119 Age : 52 Location : southside chicago Vehicle : sil 80 Reputation : 0
| Subject: Re: one of those wtf problems... August 22nd 2007, 2:04 pm | |
| do a compression test to see if all your cylinders have a sufficient pressure.. | |
| Subject: Re: one of those wtf problems... August 22nd 2007, 6:59 pm | |
| yeah just did that... found my problem
90-0-120-60
fixing it tonight after i eat | |
| Subject: Re: one of those wtf problems... August 22nd 2007, 9:34 pm | |
| oooo... awful compression all around | |
| Subject: Re: one of those wtf problems... August 22nd 2007, 9:49 pm | |
| drive it till it blows | |
| Subject: Re: one of those wtf problems... August 22nd 2007, 10:33 pm | |
| i know on a serious note............hopefully you'll be up and running by this weekend. | |
| Subject: Re: one of those wtf problems... August 23rd 2007, 7:40 pm | |
| by any chance, did you deck the head before you install it back on the block?? also you should never use the old head bolts.. always use new ones.. | |
| Subject: Re: one of those wtf problems... August 23rd 2007, 9:12 pm | |
| - profpin wrote:
- by any chance, did you deck the head before you install it back on the block?? also you should never use the old head bolts.. always use new ones..
or arp. | |
| Subject: Re: one of those wtf problems... | |
