| Trans problems | |
drifterxxl180 Fucking Noob
Number of posts : 34 Age : 41 Location : South Holland Vehicle : 95 240sx Reputation : 0
| Subject: Trans problems August 9th 2007, 11:10 pm | |
| Ok heres the problem when car sits idle for bout 15 min when you take off the rpms rise but car does not pull quite as had. Car has new clutch exedy satge 2 with lightend flywheel and new fluid also has aluminum driveshaft. could it be that scorched the flywheel or burnt the fluid? whats are your opinions | |
| Subject: Re: Trans problems August 9th 2007, 11:11 pm | |
| sure it's not an engine issue? | |
| Subject: Re: Trans problems August 9th 2007, 11:17 pm | |
| The motor shows good compression It does have a valve cover leak, still running ka24de the only that make me think that it's the motor is sometimes at low rpms it sputters but as soon as you get above 2500 it picks up fine | |
| Subject: Re: Trans problems August 9th 2007, 11:43 pm | |
| That sounds nothing like a trans or clutch problem dude. Once your in gear it has nothing to do with your trans unless its slipping, but this is NOT slipping. Sounds like a vacuum or fuel issue to me. You need to read more into it. | |
| Subject: Re: Trans problems August 9th 2007, 11:46 pm | |
| Would it be where blocked off all the Egr crap | |
Secret Squirrel Fucking Noob
Number of posts : 44 Age : 36 Reputation : 0
| Subject: Re: Trans problems August 9th 2007, 11:48 pm | |
| sputtering eh? sounds like a vacuum leak
only does it when warmed up eh? eh?
SS | |
| Subject: Re: Trans problems August 10th 2007, 12:05 am | |
| the sputtering only at low rpms. only when in idle then taking of the rpms rise but the car does not pull as hard | |
| Subject: Re: Trans problems August 10th 2007, 9:43 am | |
| Subject: Re: Trans problems August 10th 2007, 11:29 am | |
| if you changed all that, it shouldnt be an issue with the trans. unless you messed up the install. has to be something else. | |
| Subject: Re: Trans problems August 23rd 2007, 10:58 pm | |
| What I've narrowed it down to is the header. While out driving, playin around I slid it off raod and the header is cracked but it is cracked above the O2 sensor. I think that it's pulling in air and the O2 is adding fuel to compensate the air being sucked in. Think thats possible??? | |
| Subject: Re: Trans problems August 23rd 2007, 11:00 pm | |
| yeah that would do it
if the O2 is showing the ECM that the gasses in the exhaust are lean it'll add fuel to comp and try to bring the mix to 14.7:1
wouldn't hurt to seal it with some JB weld as a TEMP fix just to see if that is the problem
if it is new header, if not, then keep looking | |
| Subject: Re: Trans problems August 24th 2007, 12:08 am | |
| I'll try that for a temp fix. Or use a welder to lay a bead over the crack | |
| Subject: Re: Trans problems | |
| Trans problems | |
