| SR problems | |
| Subject: SR problems March 26th 2008, 5:53 pm | |
| Ok well my swap is out to a bad start. Well heres the problem, my SR wont start, it cranks and cranks but no start, i double checked the wiring and it was good, and i got fuel and spark, any help would be great.....i was kinda thinking timing but not so sure yet, oh and its a red top SR........ | |
| Subject: Re: SR problems March 26th 2008, 6:01 pm | |
| if you have fuel and spark, and it cranks, check compression and timing. last things to check really... hopefully it's timing. | |
| Subject: Re: SR problems March 26th 2008, 6:19 pm | |
| Fuck. Its probably gonna be timing considering the engine was just torn apart to get rebuilt. Did kasu jon say wether or not they set the timing? | |
| Subject: Re: SR problems March 26th 2008, 7:11 pm | |
| check timing, than see if CAS is set up right to the cams. | |
| Subject: Re: SR problems March 26th 2008, 8:34 pm | |
| Well me and edgar and red just had a wack at it, and failed well its late and im beat, so tommorow we will try again....... | |
| Subject: Re: SR problems March 26th 2008, 10:40 pm | |
| yeah, if your timing chain is not on right the whole use the marks thing won't work. If that is the case, just count how many links are there between your 2 marks and make sure that your cams are lined up like that. | |
| Subject: Re: SR problems March 29th 2008, 5:21 pm | |
| Also where does the nipple from the waste gate actuator go? Cause i was thinking that it goes routed to the intake am i correct.......... | |
| Subject: Re: SR problems March 30th 2008, 12:53 am | |
| throttle body - there are couple sources that you can use there. | |
| Subject: Re: SR problems March 30th 2008, 9:09 am | |
| Okay car still wont start and i removed a plug, and it was flooded, but i checked if it had spark and there is spark could it be that maybe not the ignitor is bad, also how do i know if my ecu is bad.......... | |
| Subject: Re: SR problems | |
| SR problems | |
