 really high idle
5 posters
shiftin_sideways
Number of posts : 118
really  high  idle Empty
PostSubject: really high idle   really  high  idle Icon_minitimeJune 21st 2007, 9:02 pm
i have a 90 240 with a sohc ka. it idles at 2500rpm then drops to 2000 then raises to 2500,it repeatedly does this. the engine is completely stock. i removed the aiv, welded the hole where it connects to exhaust pipe, and plugged the vacuum tubes mounted on the intake manifold where aiv hoses connect to. some other things i did that should probably be put into consideration. i tore the motor down to the block to replace all the gaskets and seals because it was leaking oil. the gas in the tank is about a year old. upon startup the speedometer pegs itself. any help would be greatly appreciated
Number of posts : 4345
PostSubject: Re: really high idle   really  high  idle Icon_minitimeJune 21st 2007, 9:30 pm
i think u should expect somekind of gunk/buildup after a year withouth running it once in a while....
PostSubject: Re: really high idle   really  high  idle Icon_minitimeJune 22nd 2007, 10:12 am
intake side vacumm leak
shiftin_sideways
PostSubject: Re: really high idle   really  high  idle Icon_minitimeJuly 16th 2007, 4:23 pm
found the vacuum leak and the tach stabilizes at 2500rpm. i adjusted the idle adjustment screw completely clockwise and rotated the tps sensor forward slightly to drop the rpms it was a success(1400 rpms), but i looked at the timing and it was way to advanced.i adjusted it to specs. yet it still idles high at 2500 rpm. even before the vacuum leak was fixed i adjusted the timing to specs. any help would be greatly appreciated. thanks
Number of posts : 1394
Vehicle : '91
PostSubject: Re: really high idle   really  high  idle Icon_minitimeJuly 17th 2007, 2:01 pm
Vacuum leak.
Look around. I had the same problem except mine was at like 1500. I had a sliced vacuum line.
Also once, my alternator was very loose and it made me have about a 1500 RPM idle. The ecu was trying to make up for the low voltage coming in and was kicking up the idle
davidricardo86
davidricardo86
Number of posts : 160
Vehicle : 92 S13 SE Coupe
PostSubject: Re: really high idle   really  high  idle Icon_minitimeJuly 17th 2007, 9:22 pm
As previously mentioned, check for vacuum leaks. Air entering the intake manifold or elsewhere after the MAF sensor will cause a high idle. I'd also check the idle devices the sohc ka uses to maintain idle ala a Nissan FSM.
really high idle
» high idle at stops help!!!!!
» FS: 3 Inch High flow cat
» Nike Dunk High Pro Sb (black/midnight Fog)
» Where to find high Temperature Brake fluid
» 9005 4300 sylvania high beam bulbs..
