 swap done not getting fuel
sleepyeyed240
Number of posts : 208
swap done not getting fuel Empty
PostSubject: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:34 pm
i swapped over everything from my running hatch to my coupe and now it wont start. i think its not getting fuel because after trying to start it i pull the plugs and they are bone dry. its getting fuel to the filter so i know its not the pump. and the first time i tryed it it fired then died right away now it wont do anything but turn over someone help!
ohhhizzzy
Number of posts : 49
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:37 pm
did you ckecked if your getting spark??
Fcknslo
Number of posts : 311
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:38 pm
if you have a fuel gauge, tee it in the fuel line and see if your getting the right amount of fuel pressure. if anything where your fuel filter is, disconnect and put int in a container and see how much fuel is coming from it. sometimes your filter is clogged but being someone that has done an sr swap shoudl know that lol. They also sell the spark testers that connect to the spark plug to check that. if you have a harbor freight by you that would be your best bet because those items i described were cheapest there for me at least. Wish you luck in your swap and hopefully things get worked out. keep us updated.
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:44 pm
filter isnt clogged its a brand new z32 filter..and im gettin spark. but wouldnt the plugs be wet and shouldnt i be smelling gas?
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:48 pm
everyone loves pics. here it is. every suspension part has been replaced with adjustable peices its all ready to go it just needs to f'in start!
swap done not getting fuel 2010-118
swap done not getting fuel 2010-120
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:49 pm
could it be my harness? i had to yank on it pretty hard to get it out of the fire wall hole
Fcknslo
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:51 pm
yes and no. it does make sense that if you were cranking and it wasnt starting that if were spark your plugs would be covered in gasoline and would reak of them. do you hear your fp prime? have you checked with a test light to see if it has power? sometimes it could be the ground too. when you did the swap did you mix up the fuel feed and return lines? best thing to do is get a fuel gauge and heck to see if your getting the right pressure, borrow from a friend or get one, they are not that expensive. when I did work on my e30, i mixed the fuel lines up and that was my problem. if worse comes to worse and those are both good (considering you have fuel and spark) maybe its your maf?
Fcknslo
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:53 pm
if it were the engine harness its not connected to the fuel pump so i would assume it wouldn't be the harness thats the problem if you think its fuel.
didnt read the thread, but check to see if you have the lines going to the fuel rail reversed. That would cause the motor to nor run, or to just briefly run before dying quickly
Fcknslo
p.s thats a lot of motivation to turbo a single, and i really want your hatch, i just need to start saving up the cash.
Fcknslo
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 10:54 pm
Thats what I told him, its very common to do that and its a simple mistake that happens often. something as simple like that is causing you to enjoy such a little car
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 11:46 pm
yeah at first i did mess up the lines but that was before i even tryed starting it. and i replaced the maf with one i had that i know was good too. and when the engine was running in the hatch when i even touch an injector connector it would misfire so maybe the connections are fucked now that i was messing with it?
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 16th 2010, 11:48 pm
and its got a bunch of pressure i pulled the line off that comes from the filter and it shot everywhere. and made a loud noise. i have a walbro i might as well through that in there
Fcknslo
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 17th 2010, 6:48 am
well seems as if you have fuel, and since you did the swap you should know which side is feed and which is return on the fuel rail.
best bet is to invest or borrow a spark tester and see if your getting spark, and from there if you are not check to see where on the wiring harness is the connection not going through and either a hack it and reconnect it, or jsut get a new wiring harness. but before you do any of those, check to make sure if your getting spark or not.
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 18th 2010, 1:36 pm
update: car fires off of starting fluid. so i know im getting spark. all the injectors have power what else could it be??? is there suppose to be power going to the temp sensor?
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 18th 2010, 3:56 pm
okay im an idiot. the fuel lines were right in the first place. i was thinkin that the feed line would go to the fpr. low and behold i was wrong. thanks for all the help though guys!
Fcknslo
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 18th 2010, 7:13 pm
fpr usually goes to return but glad to see you got it going, when can i come up there and get a test drive? I want to see what it feels to have a single cam turbo, thats my plans for the winter/spring.
sleepyeyed240
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 18th 2010, 10:55 pm
when you buy my shell haha. the clutch is slippin like a bitch right now.. it didnt until i got up in the rpms when it was in my hatch. now right when its engaging its slippin. and i gotta get a 4 wheel alighment cause the dude that put the suspension parts in didnt get it done yet. so its my winter/spring project too haha
Fcknslo
PostSubject: Re: swap done not getting fuel   swap done not getting fuel Icon_minitimeNovember 18th 2010, 11:04 pm
haha. I don't got that cash to buy your shell otherwise I would in a heartbeart. to bring it back to chicagothe distance will be a bitch to cover.
gl and I'm looking to see some more progress on this. keep us updated.
» Fuel issue or timing?? help?
» dumping fuel + stall
» Fuel Cut Problem!
» WTB SR fuel rail
» fuel pump and fuse.
