| KA24E (i know) loss ofpower when warmed up? | |
+8D*S Dstar blklabel44 jdmj914 Nachtmensch Bliz Khalifa whiterps13 D*S Tomy Guns mishkin_707 12 posters |
mishkin_707 Forum Frequenter
| Subject: KA24E (i know) loss ofpower when warmed up? September 17th 2010, 7:39 am | |
| whats up peoples, ok i searched everywhere and now im asking the experts, i've had this car since 2001 drove it til 2002 and stored it til 2006, i started driving it again in 2006, when i started the car it would run fine, after it was warmed up i noticed from a stop it would take off really fucking slow as if it had no power. til this day it does it but now it's driving me crazy, i checked my vacuum lines, tps, fuel injectors, fuel filter is new and grounds are good also the ecu is only giving me a 55. anyone got any ideas? only when the car is warm from a stop it will drive like i have 2 fat guys and three midgets sitting in my trunk it's a SOHC with 230k on it im just trying to keep this motor running until my swap, i searched google and other 240sx websites and everything i came across were not answered or flaming or shit i already checked on my car. im stumped so that why im asking the experts on here, thanks in advance | |
D*S Tomy Guns DS! DS! DS!
Number of posts : 817 Age : 36 Reputation : 19
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 17th 2010, 12:17 pm | |
| Most likely cause of the miles son. | |
whiterps13 Post Enthusiast
Number of posts : 1385 Age : 36 Location : Rockford Vehicle : S4 Reputation : 11
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 17th 2010, 12:22 pm | |
| I mean its a fucking SOHC with 200k+miles on it. It made like 135 horsepower in 1990. Its now 2010. What do you expect? Its not going to rip your face off. | |
Bliz Khalifa Established Member
Number of posts : 886 Age : 37 Location : House of Love Reputation : 20
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 17th 2010, 12:24 pm | |
| factory exhaust still? Backpressure test for the cat if you still have one....
Check compression? | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 18th 2010, 2:06 am | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 18th 2010, 2:00 pm | |
| - VanillaFace wrote:
- factory exhaust still? Backpressure test for the cat if you still have one....
Check compression? i didn't even think about that, i'll pull the cat later, compression was 165 across the all the board, couple people say thats bad and others say its good, i dunno the factory specs for compression, good idea about the cat - whiterps13 wrote:
- I mean its a fucking SOHC with 200k+miles on it.
im not expecting it to be a race car, i just want my car to move from a stop sign, but thanks for the help lil guy | |
jdmj914 Forum Frequenter
Number of posts : 282 Age : 35 Location : United States Vehicle : 2WO4TY Reputation : 0
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 18th 2010, 5:07 pm | |
| Maybe check all your ignition components. Pay special attention to your plug wires. You may need to upgrade. There are ALOT of variables here. " Compressing air raises its temperature. However, you would like to have the coolest air possible in the cylinder because the hotter the air is, the less it will expand when combustion takes place." Causing loss of power. Also your thermostat. It's probably running hotter than normal. | |
blklabel44 Light Duty Poster
Number of posts : 102 Age : 34 Reputation : -2
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 18th 2010, 5:09 pm | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 18th 2010, 7:11 pm | |
| ^This guy's posts are starting to crack me up. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 18th 2010, 11:21 pm | |
| - jdmj914 wrote:
- Maybe check all your ignition components. Pay special attention to your plug wires. You may need to upgrade. There are ALOT of variables here.
" Compressing air raises its temperature. However, you would like to have the coolest air possible in the cylinder because the hotter the air is, the less it will expand when combustion takes place." Causing loss of power. Also your thermostat. It's probably running hotter than normal. well im doing my plugs, wires and thermostat tomorrow so hopefully that will help, i'll most likely pick up a new ignition coil tomorrow. - blklabel44 wrote:
- spark or fuel
well thank you bill nye the science guy i checked my cat converter, looked ok, i borrowed my friends and put in on my car, drove her around and same shit so the cat is ruled out. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 19th 2010, 11:11 am | |
| bill bill bill bill bill bill bill bill bill | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 19th 2010, 1:54 pm | |
| check for vacuum leaks. around the intake tube and stuff.. sounds like maybe un metered air?
just a thought. without a video. or a better definition i cant tell. it was pretty vague definition. does it sputter. or does it just feel really really slow? | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 19th 2010, 4:40 pm | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 19th 2010, 5:02 pm | |
| - hs13kls wrote:
- check for vacuum leaks. around the intake tube and stuff.. sounds like maybe un metered air?
just a thought. without a video. or a better definition i cant tell. it was pretty vague definition. does it sputter. or does it just feel really really slow? a video would not help, actually have to be in the car to notice it, vacuum lines all checked out good, i doubt it's the MAF cause i can rev past 2500 rpm just fine, no sputter and no misfiring, all i can tell is when the car gets warm thats when it does it, a few times it felt like it wasn't going to move, it only does it when im at a red light or a stop sign, only the initial take off other than that the rest of the gearing feels good, definitely not the clutch slipping, feels like im trying to pull a semi truck with my car. i say mods change blklabel44's name to bill nye | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 24th 2010, 5:30 pm | |
| so did everything, piece of crap does the same thing, like there's no torque, only when it's cold it seems like it has torque, who knows? | |
tony89 Fucking Noob
Number of posts : 36 Age : 35 Reputation : 1
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 24th 2010, 6:09 pm | |
It made like 135 horsepower in 1990. Its now 2010. What do you expect? Its not going to rip your face off. What more do you need to hear? truth sucks | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 24th 2010, 6:32 pm | |
| Your a fucking idiot. And youve got one foot out the goddam door. He is describing a sudden and almost complete loss of power and forward propulsion. Not a tired fucking motor. Have you ever driven a single? They arent any slower or weaker than a twin cam. Bunch of fucking idiots. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 24th 2010, 6:43 pm | |
| Buy another one with less miles. SOHCs are like $100. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 24th 2010, 6:48 pm | |
| Those things are getting harder to find. | |
| DOHCs yes, SOHCs are still pretty easy to come by. Most are beat to the ground though. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? September 24th 2010, 8:34 pm | |
| - DS D*star wrote:
- Those things are getting harder to find.
im with D* on this one, when i see a SOHC, it's blown or in pieces with missing shit, DOHC are easier to come by lately from what i've seen on craigslist, a person i know had given me a single cam and said it ran fine, seemed like i scored a deal till i took it apart, looked like he ran it with no oil and piston rods were bent to shit. luckily i didn't try to put it in or pay for it at that matter. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? November 8th 2010, 3:47 pm | |
| ok i finally found out the problem, fuckin temp sensor is fucked up, i disconnected it and drove it for like and hour and nothing, it even starts up on the first time every time, the sensors i keep getting from vato zone arent working i guess or they are wrong, the OEM one i have is red where the wiring plugs in, the ones i get from vato zone are black and thats all they have by what they tell me, $26 down the fucking drain, anyone have a SOHC coolant temp sensor i can buy? i got a for sale tread if you wanna check out i will do an even trade for the stuff i got for it if you need anything i got, if not just let me know a price cause im not wasting time with vato zone | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? November 8th 2010, 4:21 pm | |
| All S13 temp sensors are the same. S14 are different. Color shouldn't matter, and most of the time different part companies use different colors. rockauto.com has sensors for $7-25 plus shipping.
AIRTEX / WELLS Part # 5S1523
NISSAN 300ZX 2+2 (1989 - 1996) NISSAN 720 PICKUP 1986 NISSAN AXXESS (1990 - 1991) NISSAN AXXESS 4X4 1991 NISSAN D21 PICKUP (1986 - 1994) NISSAN D21 PICKUP SE (1991 - 1994) NISSAN D21 PICKUP XE 1994 NISSAN MAXIMA (1989 - 1991) NISSAN MAXIMA GLE (1995 - 1996) NISSAN MAXIMA GXE (1992 - 1996) NISSAN MAXIMA SE (1992 - 1996) NISSAN NX (1991 - 1993) NISSAN PATHFINDER (1987 - 1992) NISSAN PATHFINDER LE (1994 - 1995) NISSAN PATHFINDER SE (1990 - 1995) NISSAN PATHFINDER XE (1990 - 1995) NISSAN PICKUP 1995 NISSAN PICKUP KING CAB XE-V6 1996 NISSAN PICKUP SE 1995 NISSAN PICKUP SHORT BED XE 1995 NISSAN PICKUP XE 1995 NISSAN PULSAR NX SE (1988 - 1989) NISSAN QUEST GXE (1993 - 1996) NISSAN QUEST XE (1993 - 1996) NISSAN SENTRA (1989 - 1993) NISSAN SENTRA CLASSIC 1993 NISSAN SENTRA E 1994 NISSAN SENTRA GXE 1994 NISSAN SENTRA LE 1994 NISSAN SENTRA SE 1994 NISSAN SENTRA SE-R (1991 - 1994) NISSAN SENTRA XE 1994 NISSAN STANZA (1986 - 1992) NISSAN VAN (1987 - 1988) | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? November 9th 2010, 9:21 pm | |
| thanks a load, the ones i kept getting from vato zone are black and didn't have the grooves like my OEM one does so the connector can fit onto the sensor, now a dumbass question, i ran it for the past two days without the sensor plugged in, my gas mileage went up significantly and my start ups also start on the first try and no more loss of power, anyways will running my car without the sensor mess up anything?
just til i get the sensor in, thanks for the website and part number, nissan wants $64 for one. | |
| Subject: Re: KA24E (i know) loss ofpower when warmed up? November 9th 2010, 10:13 pm | |
| That just sends the information to your temp gauge on your dash. So if you're positive your shit is not gonna overheat then go ahead rock out.
| Subject: Re: KA24E (i know) loss ofpower when warmed up? | |
