 partout.
lopez6558
10 posters
Go to page : 1, 2  Next
partout. Empty
PostSubject: partout.   partout. Icon_minitimeAugust 2nd 2010, 11:49 pm
Pick-up only
847 644 0469
I dont have pictures of everything, pm me if you need a specific picture of a part.
So here it goes- parting out my S13.
Everything is for sale.
The shell is sold.
What I have:
HKS 264/264 SR20 in/ex cams
-$375 takes both of them. Excellent condition.
JWT Adjustable cam sprockets
-$100, already mounted on the HKS cams.
***$450 for cams with cam sprockets***
SR20 Greddy Rocker arm stoppers
-$50, comes with all mounting hardware.
SR20 Exedy Stage 2 clutch w/ pressure plate[b]
-$200, in good condition and properly broken in.
[b]SR20DET motor swap
-$1400, long block with alternator, starter, belts, flywheel, spark plugs, stock injectors, Cosworth 1.8mm head gasket, turbo manifold, fuel rail, throttle body, all engine sensors, motor mounts, distributor. Motor has a redtop block, and a blacktop head, assembled by LongGrain. Compression is perfect across all cylinders, no issues whatsoever.
SR20 bottom mount down pipe
$100, comes with all needed flanges, has a couple scrape marks on the bottom, no cracks or bends whatsoever, good condition.
TiTek (Denzo) 550cc side-feed long-tipped injectors
-$350, absolutely amazing injectors.. Used them on my SR setup for less than 1000 miles. A must-have for high-boost applications. Paid $580 brand new from Touge Factory. Perfect condition, guaranteed, all the o-rings and plastic clips are in perfect condition. Comes with the harness plugs.
Full SR engine harness, uncut
-$175, Good condition when pulled, no cuts or anything anywhere, does not include ignitor or ECU.
S13 SR20 transmission
-$200, no grinds whatsoever, always filled with amsoil transmission oil
S13 Manual non-abs driveshaft
-$120, good condition, comes with all needed nuts, bolts, hardware etc.
R32 VLSD w/ 5bolt axles and half shafts
-$300, 4.36 final drive gear ratio, filled with kaaz gear oil when I put it in, comes with 5bolt axles/half shafts, uses the r200 diff housing- direct bolt-on to s13 chassis.
Xcessive Motorsports S13 skid plate
-$100, comes with all mounting hardware, brand new in the box, never even opened. Cheaper than online.
2003 350z 5x114.3 wheels w/ tires
-$300, no curb rash or anything, rear tires are shot but I have another set of tires with about 50% tread left that I will include
OEM SR20 radiator w/ single altima fan
-Used this on my SR setup for awhile, never overheated, great condition, new radiator cap included
Circuit Sports S13 RUCAs
-$100 in good condition, fully adjustable, I had them set to -5 camber.
Greddy oil catch can setup
-$50 with lines, breathers, mounts.
Apex GT Spec 3.5” full exhaust
-$300, perfect condition with no leaks, amazing sounding exhaust on an SR. Goes for $600+ new. $350 with bottom mount SR down pipe.
Fake Bride Recliner seat w/ side-mount bride passenger seat rails
-$300, fa kebride seat, no rips/tears, fits a size 34 waist snugly, cool passenger seat.
Greddy Boost guage
-$100, comes with 40" rubber vacuum line. Measured in mm/hg.
Stock S13 leather seats
-$20 each, good condition, don’t think they have any rips but the drivers side is pretty worn.
Stock S13 6bolt axles
-$100 takes both
SR coil packs
-$20 each, all work fine. I have eight.
HKS SR20 t25/t28 hotpipe
-$100, bought new from Touge Factory, comes with HKS flange. Polished aluminum with no dents or scratches.
HKS SSQV blow off valve
-$100, used for ~3000 miles with zero issues
Silicone couplers with clamps
-$10 each, each comes with needed clamps.
Power steering assembly from S13
-$100, comes with power steering pump, belt, clips, bolts, everything you need to install power steering on an SR20.
Greddy Turbo Timer
$60, comes with wiring harness
SR oem upper/lower radiator hoses, two sets
-$40 each
Brand NEW SR alternator
-$120, rebuilt by Akram auto on Clark/devon. Cost $90 alone to rebuild.
KA alternator
-$50, good working condition w/ no issues
S13 SR20 flywheel
-$50
SR transmission gasket
$30
Stock S13 mirrors
-$20 takes both
OEM s13 SR fuel pressure regulator
-$50
OEM s13 IACV
-$50
Stance aluminum water pump pulley
-$40 , painted black, paint is chipping though and you can see the gold stance anodized metal underneath
S13 coolant resovour, repaired with no cracks or leaks
-$20
Pictures:
partout. 4799639334_373c1041ee
partout. 11
partout. N1153080791_30466549_4772-1
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 4:23 am
Im pretty open to trades for parts,,
PM me if you need a pic of something specific
im looking for a KA swap, if anyone has one and is looking for an SR we'll work something out
lopez6558
lopez6558
Number of posts : 321
Vehicle : 95 240sx coupe/96 240sx coupe
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 8:53 am
pm'd
http://grimcreations.weebly.com/
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 8:54 am
Hold that catch can for me till, thursday.
Pics of the RX8 seats
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 11:12 am
updated price, the SR harness in my car went bad after i had someone wire a couple things, pretty sure it needs a new lower harness. letting the harness go AS IS for $150. Not bad at all if you have even basic wiring experience. Comes with EVERYTHING except the ecu itself.
ill have it here for you trucky
crappy picture but you can see how they look, theyre good seats though.. super comfy, i always get people asking if my car is a rotary..
partout. RX8seats
Number of posts : 875
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 1:44 pm
yo i need that intercooler asap
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 3:36 pm
oil cooler setup is not from TF..
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 3:38 pm
maybe i heard wrong from you then, but either way its a legit earls oil cooler setup.
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 4th 2010, 3:47 pm
yea, I bought a section of line and all the fittings from anplumbing.com and built it myself.
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 5th 2010, 11:15 pm
bump
enthalpy ECU sold
Number of posts : 401
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 6th 2010, 3:20 am
thanks simon
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 6th 2010, 7:32 pm
yup.
will trade parts for a stock 240
lmk
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 6th 2010, 8:32 pm
rx8 seats sold
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 9th 2010, 7:24 pm
to the top
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 9th 2010, 7:32 pm
bump pictures added
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 29th 2010, 7:42 pm
BUMP pictures added, more parts too
for some reason some of them turned out gigantic
I will be available tuesday and thursday afternoons for parts pickup.
Number of posts : 816
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 30th 2010, 12:25 am
yo hit me up about that seat son.
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 30th 2010, 1:54 am
texted your sexy ass
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 30th 2010, 11:17 am
also have a pignose lip for sale, $50 takes it
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 30th 2010, 3:30 pm
5lug and rear s14 se rotors are sold
torquem90
Number of posts : 3
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 31st 2010, 11:39 pm
by any chance u got any exhaust parts
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeAugust 31st 2010, 11:46 pm
wat do u mean exhaust parts? who are u anyway?
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeSeptember 1st 2010, 4:47 pm
yea i got a gt spec apexi for sale
exhaust parts lol
partout. Car1
pending sale for piggy lip, bride seat/rail, coils/radiator/fan, greddy ras, fmic core and ignitor
5lug sold
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeSeptember 2nd 2010, 11:43 am
pretty much have two SR swaps taken apart in my garage, if anyone needs a specific part shoot me a PM, chances are ill have it
partout. Empty
PostSubject: Re: partout.   partout. Icon_minitimeSeptember 6th 2010, 3:42 am
coils, fuel pump sold
partout. Empty
partout.
Page 1 of 2Go to page : 1, 2  Next
» 2jz 240 partout
» Partout #5
» DSM Partout
» S13 partout
» BEASTMODE PARTOUT
