 Jack Bleeding?
7 posters
Jack Bleeding? Empty
PostSubject: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 1:00 pm
how do i bleed/add hydraulic fluid in a jack? mines dying. past a certain point, it wont lift anymore (like it used to) and i can hear the fluid move inside when i let it down.
or is it time for a new one? i've had this one since 04/05
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 1:18 pm
i would look into a new one.
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 1:24 pm
i was looking into this one
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=11737
may as well get a low pro jack while im at it...
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 1:43 pm
only problem i see with that one is that it doesnt say if its aluminum or not.
i would not buy a race jack like that thats NOT aluminum, especially if you plan on doing any tracking or anything, steel race jacks are really heavy and just a burden to lift into and out of a car if you ever take them anywhere.
i know harbor freight has some really nice low pro aluminum race jacks for $200 and under. i would check them out.
Number of posts : 1109
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 5:51 pm
thats where i got mine, i <3 harbor freight.
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 6:21 pm
taka check your PM's homie.
shiftin_sideways
Number of posts : 118
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 10:06 pm
I have a similarly designed floor jack from matco. It weighs 120lbs.
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 10:18 pm
^^^ yea FUCK that...
aluminum is the cat's pajamas
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 25th 2009, 11:15 pm
hahaha
i do have a smaller jack that i can bring to track events.
Number of posts : 593
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 26th 2009, 1:04 am
There should be a valve on you floor jack that you would just open up and add fluid into. Any autoparts or hardware stores such as Sears should carry floorjack or hydraulic fluid.
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 26th 2009, 12:13 pm
ATF
240sx4u
Number of posts : 85
PostSubject: Re: Jack Bleeding?   Jack Bleeding? Icon_minitimeJanuary 26th 2009, 1:34 pm
I added fluid to my aluminum craftsman jack and it solved that problem. Just add fluid until its full, pump it up and lower it a few times. Add more fluid. Not sure if thats the right way, but it worked for me.
Jack Bleeding?
» power steering bleeding issue
