xxcrashxx XI Fucking Noob
Number of posts : 52 Age : 34 Location : south side Vehicle : 93 nissan 240sx Reputation : -6
| Subject: power steering bleeding issue September 14th 2009, 9:09 pm | |
| i have had an issue for the past 3 days after i did all this work on my car i filled the resevoir under a quart amount but i know i took more out. there is a special tool to connect to the system to bleed it correctly but ive done all that it says on 240sxtech.com just wondering if anyone else came up with something to make it easy to bleed. Do you think that NTB will bleed it when i take it to get an alignment? any info would help thanks | |
Number of posts : 355 Age : 113 Location : North Riverside under the mall Vehicle : 1991 240sx fastback sr20det part 2 Reputation : 12
| Subject: Re: power steering bleeding issue September 14th 2009, 10:34 pm | |
| Power steering is overated. If you busted your small hard lines youll have to go aftermarket as the dealers no longer sell them and used is not trust worthy I went thru 4 replacements before giving up. The price of the aftermarket stuff did not do it for me. I now enjoy the impressive forearms ive developed from going without. | |
| Subject: Re: power steering bleeding issue September 14th 2009, 11:15 pm | |
| i dont even think u need to bleed the system, just have someone, turn the steering wheel as u pour fluid... | |
| Subject: Re: power steering bleeding issue September 15th 2009, 1:17 am | |
| yea i did the turn the steering wheel bs but i guess im impatient so i will do some more later and hopefully show you guys my car as it sits right now | |
| Subject: Re: power steering bleeding issue September 15th 2009, 1:40 am | |
| all you need to do is keep turning the wheel lock to lock. just keep the reservoir full | |
| Subject: Re: power steering bleeding issue | |
