| Building all the wrong cars | |
+70Matej JohnnyDrift David fresheg6 Vegas13 Cyclohexyl Coupe sleepyeyed240 ill roller ferrarisx D*S Homeboy. YELLOW D*S Tomy Guns danstel456 Trucky's bitch. AMD 240 blklabel44 Adrian_S13 240slider8 shiftin_sideways zero RacerX evanger drftx s14rob s13 brian Curtis DeAngelo Nelson II LeMoine gOtPUrPL3 Xmax koukimonster 240nut 007 Scuba Steve 14k s14 mrkan mikemadison_09 k c djexpo energ hs13kls JAYYS Dirty Dee Los Vlados Locos D*S Dave his180sx Mr.BackFire Jay splitime D*S Roski JakeS14 rcl1221 Nackers danielekfuj FusionR300zx SIMON timmuh SylviaFan Flicktitty ilia Stab Master Sharson DJ Longdick whiterps13 RAD MIKE Circa 3006 D*S Dstar RAMM D*S Trucky sad REVGASM Specter Nachtmensch 74 posters |
Number of posts : 3100 Age : 34 Location : LV-426 Vehicle : Nostromo Reputation : -26
| Subject: Re: Building all the wrong cars November 17th 2009, 10:17 am | |
| Subject: Re: Building all the wrong cars November 17th 2009, 4:31 pm | |
| sand paper (400, 800, 1000, 1200, 1500, 2000) and metal polish | |
| Subject: Re: Building all the wrong cars November 17th 2009, 5:36 pm | |
| Subject: Re: Building all the wrong cars November 17th 2009, 7:54 pm | |
| Now I need to do the rest.... | |
zero Fucking Noob
Number of posts : 86 Age : 33 Reputation : -2
| Subject: Re: Building all the wrong cars November 17th 2009, 10:32 pm | |
| dumb question but could you spray a clear coat over it so it stays cleaner or would it just burn off? | |
| Subject: Re: Building all the wrong cars November 17th 2009, 11:13 pm | |
| why? it just needs to be wiped down if it is dirty, like any stainless. | |
Number of posts : 4345 Age : 34 Location : sOuF-ChI Reputation : -37
| Subject: Re: Building all the wrong cars November 18th 2009, 10:10 am | |
| the clear would ooze off with the heat. | |
djexpo Forum Frequenter
Number of posts : 452 Age : 35 Location : Chicago Vehicle : 89 240sx Coupe Reputation : -1
| Subject: Re: Building all the wrong cars November 19th 2009, 6:54 pm | |
| Subject: Re: Building all the wrong cars November 19th 2009, 9:21 pm | |
| finally got the head off (after obtaining the correct, 12mm triple square bit) Block looks pretty good. You can see the MMC coating (all aluminum cylinder walls) which is supposed to strengthen the walls and provide a low friction coating Yup, needs new valves. | |
| Subject: Re: Building all the wrong cars November 20th 2009, 8:55 pm | |
| I pulled off the oil pan, and was greeted by part of the girdle that came with it. It was a small corner that was by the oil pump. I'll have it welded back on by my coworker.
Oil that was in there was all milkshake'd. So I think this motor suffered from a BHG... or something. Could be cause for the leakage as well as all the coolant everywhere. I didn't have time to pull the girdle/rod caps off to check the bearings.
But, I think at this point I will be doing a full build. I'd hate to do all the work to the head, just to have the bottom end fail. It would also give me peace of mind.
Sorry no pics. I can snap some next week. | |
| Subject: Re: Building all the wrong cars November 24th 2009, 6:49 pm | |
| I just got my box of 2zz parts. Still need to buy (minimum): Throttle body Throttle cable bracket ECU 2ZZ MAF Gaskets APR head studs Circuitworx oil pump gear New oil pump Valves Valve springs Ti retainers | |
| Subject: Re: Building all the wrong cars December 1st 2009, 2:34 pm | |
| Selling my Techno Pro Spirit roll bar | |
| Subject: Re: Building all the wrong cars December 15th 2009, 12:59 am | |
| Already Bought MWR 2ZZ-GE Valve Set- Flat Face MWR 1ZZ / 2ZZ High Performance Valve Stem Seal Kit MWR Circuitworx Assembled Oil Pump - 2ZZ-GE Toyota 2ZZ OEM lift bolts (pair) Toyota OEM Front Crankshaft Seal - 1ZZ-FE, 2ZZ-GE Toyota OEM Rear Crankshaft Seal - 1ZZ-FE, 2ZZ-GE Toyota OEM Head Gasket - 2ZZ-GE Toyota OEM Oil Pickup Gasket - 2ZZ-GE Toyota OEM Oil Pump Gasket - 2ZZ-GE
List To Buy: Throttle Body w/ IAC ARP Head Studs Pass. Side Mount Cosworth or Hondata IM heat shield gasket ECU
Maybe Depending On Funds: Eibach Valve Springs Cams?
Running tab so far: $400 Motor $350 Misc used OEM parts $750 12/15/09 Valves, Gaskets, Oil Pump Total $1500
This shit got expensive....
Last edited by Nachtmensch on December 16th 2009, 3:16 pm; edited 1 time in total | |
shiftin_sideways Light Duty Poster
Number of posts : 118 Age : 39 Reputation : 1
| Subject: Re: Building all the wrong cars December 15th 2009, 12:46 pm | |
| What would be the benefit of high performance valve stem seals as opposed to normal valve stem seals? | |
| Subject: Re: Building all the wrong cars December 15th 2009, 12:58 pm | |
| Subject: Re: Building all the wrong cars December 15th 2009, 2:58 pm | |
| Subject: Re: Building all the wrong cars December 15th 2009, 3:00 pm | |
| It's more in regards to what materials are used in the high performance valve stem seal as opposed to a valve stem seal you would buy at Autozone. I don't see any benefit besides not sheering at higher rpms causing engine problems. | |
| Subject: Re: Building all the wrong cars December 15th 2009, 3:07 pm | |
| I saw them as they were $15 and needed them anyway. Others are $20.
Call this number and ask: (248) 624-9820 | |
| Subject: Re: Building all the wrong cars December 15th 2009, 4:15 pm | |
| the fuck would you buy any part at autozone... ever | |
| Subject: Re: Building all the wrong cars December 16th 2009, 3:08 pm | |
| That was fast... | |
| Subject: Re: Building all the wrong cars December 17th 2009, 10:38 pm | |
| Ordered:ARP Head Studs Supertech Valve Springs Supertech Ti Retainers Oh, and good news; my bearings look ok Just some normal wear. (jounal #2 has some oil on it, so it looks worse than it is) This motor had a BHG too as proven by the milky oil. I'm just glad the bearings are fine. | |
| Subject: Re: Building all the wrong cars December 17th 2009, 10:55 pm | |
| I would change them anyway... as long as you had it open. | |
| Subject: Re: Building all the wrong cars December 17th 2009, 11:00 pm | |
| you get the supertech springs and retainers form their ebay listings?
Ive been debating getting either their springs or Tomei's | |
| Subject: Re: Building all the wrong cars December 18th 2009, 8:09 am | |
| - Dirty Dee wrote:
- you get the supertech springs and retainers form their ebay listings?
Ive been debating getting either their springs or Tomei's Nope, through work for a good discount. I'm too cheap to change the bearings. They look fine, and it saves me money. When it dies, I'll redo the bottom end with better pistons, rods, and bearings. | |
| Subject: Re: Building all the wrong cars December 19th 2009, 12:11 am | |
| Got an ECU.
just need a TB with IAC and a passenger's side mount | |
| Subject: Re: Building all the wrong cars | |
