 Meh need help with Infiniti
5 posters
Push
Number of posts : 43
Vehicle : Toyota Cressida
Meh need help with Infiniti Empty
PostSubject: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 22nd 2008, 5:01 am
Yea I know I don't post here often... I will keep it short and simple... I have a 95' Infiniti G20... SR20DE motor yada yada 5-speed. I got rod knock, swapped the motor for another sr20de off the same year 95' g20, and I can't get the damn car to start. The problem is something electrical... The check engine light does not go on, motor cranks but does not get spark. My timing is right, my motor is good and did run fine before... Its something to do with wiring because my ECU is getting no power. Its been 2 months and I am getting frustrated... If anyone local knows his Nissan shit, and can help me out let me know. I will definitely make it worth your while... I really would like to have this car running again asap! Thanks!
-Push
Number of posts : 593
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 22nd 2008, 8:01 am
I'll PM you my buddy's info if its ok with him to give his info to you. He is pretty good with SRs.
Official Chef
Official Chef
Number of posts : 666
Vehicle : 1991 Nissan 240sx
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 22nd 2008, 12:09 pm
Check your grounds!
http://stores.ebay.com/Rated-R-Performance
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 23rd 2008, 3:57 pm
damn Push, stick to them cressidas.
Sorry you're having trouble, but if your ECU isn't getting power, check fuses and relays, make sure IGN relay is getting signal, etc.
Push
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 24th 2008, 8:27 pm
Thanks, I checked the fueses and relays all look good, not sure what the IGN relay is?
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 25th 2008, 12:42 am
ignition
make sure its sending power to the ECU, if it is, track down the wiring as there must be a break in there somewhere. (possibly rubbed through?)
zweetz32
Number of posts : 22
Vehicle : 90 300zx TwinTurbo
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 25th 2008, 1:13 pm
check to see if you're getting a spark. Get a screw driver, stick it in the coil pack or the wire hold it close to the block and get someone to crank the car. You should see sparks. If not, you're not getting a spark. If you are getting a spark, check if you're getting fuel. Get a noid light and check for that. Also how do you know the ECU is not getting any power?
Push
PostSubject: Re: Meh need help with Infiniti   Meh need help with Infiniti Icon_minitimeJanuary 26th 2008, 2:15 pm
I am not getting spark... Meh, anyone willing to make a trip out here and help me out? I will buy steak, or whatever you want! Make it a little mini-meet or whatever... I just really want this car running haha... I got a heated garage, and the lights and tools... Let me know..
» 1991 infiniti q45
» Chicagoland Nissan/Infiniti BBQ 8/30/09
» Fields Infiniti Meet/BBQ 060609 aka TODAY!
» All Nissan/Infiniti Meet 08/27/11 Busse Woods
» All Nissan/Infiniti Meet BBQ May 23rd 11am to Sunset
Chicago Area 240sx :: Assorted Automotive :: Close Encounters-
