| t28 BB turbo | |
Berzerker Light Duty Poster
Number of posts : 194 Age : 38 Reputation : -1
| Subject: t28 BB turbo July 28th 2007, 12:14 pm | |
| Ok my question is this i got t28 BB, i hooked up the oil feed line, was testing if it was leaking anywhere, i pluged up the oil drain line and tryed to blow it through and the air comes out of turbo intake side? its not supost to happen like that right? i need to rebuild it? Change oil seals? Or is it supost to let air out of there in order to drain better, because i got a t25 and i did the same thing, the air barly comes out when I plug up all the holes, but for the t28 bb air passes more freely...fk impissed any1 got any info to help? | |
k c Established Member
| Subject: Re: t28 BB turbo July 28th 2007, 10:16 pm | |
| i have a new gt28r basically the same thing, just blown through it. no air whatsoever. was your t25 blown? | |
| Subject: Re: t28 BB turbo July 29th 2007, 2:21 am | |
| I dont know because i bought that from a person, both of those turbos are used, is ur gt28 did u try to plug up the oil drain and blow air through the oil feed line? | |
| Subject: Re: t28 BB turbo July 30th 2007, 9:59 am | |
| yea i did it both ways, but i dont think thats the proper way to determine if the turbo seals are blown. i say just run it on the car and see if you get some blue smoke coming from the exhaust or oil in your hotpipe and intercooler piping. | |
| Subject: Re: t28 BB turbo July 30th 2007, 12:23 pm | |
| Yeah that is what im going to do. | |
profpin Light Duty Poster
Number of posts : 119 Age : 52 Location : southside chicago Vehicle : sil 80 Reputation : 0
| Subject: Re: t28 BB turbo August 2nd 2007, 7:48 pm | |
| your turbo should not leak air between the seals whatsoever.. | |
| Subject: Re: t28 BB turbo August 2nd 2007, 9:53 pm | |
| If not then im fucked,and all the instaling I did I will have to redo zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz | |
| Subject: Re: t28 BB turbo August 2nd 2007, 10:02 pm | |
| don't worry about it too much, i bet the 2nd time around u can do it as twice as fast, if this was the first time for you | |
| Subject: Re: t28 BB turbo August 2nd 2007, 11:49 pm | |
| Yeah it is 1st time around, also not much room there lolx, | |
| Subject: Re: t28 BB turbo | |
| t28 BB turbo | |
