| The CA240SX Wheel Fitment and Ride Height thread. | |
+17D*S Roski evanger D*S Trucky Matej Teo Pepe Pepe Olly DAELEN Bliz Khalifa D*S Dave Steve Nachtmensch YELLOW DJ Longdick energ FusionR300zx D*S Dstar 21 posters |
| Subject: The CA240SX Wheel Fitment and Ride Height thread. November 21st 2011, 4:45 pm | |
| I dont know why we dont already have one of these. Lets us post how we get down. Post your setup and all previous setups of yours. Doesnt have to be an S chassis, if youre a member and youre reading this and dont have faggot fitment, post your shit. This thread will be used for future fitment reference for members/guests, and also a place for fitment questions to be asked.
NOTE: Include all specs with the pics. Post wheel size, tire size, offset, fender spec, even coilover and alignment specs.
Here I ho with all my previous shit. SSR Formula Mesh 15x8 -15 F/R 205/50R15 F 195/55R15R Stance GR+pros full low, maxed out front camber And then eventually raised up with 195/60 Kumho fronts and 185/60 rears for party and bullshiting. Sportmax 006 17x9 -3 F 17x9 -15 rear 215/40R17 Falken RT615 F 225/45R Kuhmo MX R Stance GR+pros full low with all collars removed,helper springs still in the back, maxed out front camber M2 Hanbai DT05-R "D" 17x8.5 -0 F 17x9.5 -15 R 215/40R Federal 595 all around Dmax 40mm front fenders, BN sports 50mm rear fenders E-motor coilovers full low with all collars removed Enkei RPF1 17x9.5 -2 F 17x10-32 R 235/45R 17 F 225/45R17 R Origin 20mm front fenders, Origin 50mm rear fenders Stance GR+pros at full low, max camber front Enkei RP03 18x9 -0 F 18x10-30 R 235/F 215R/40R18 Federal 595 Dmax 40mm front fenders, BN 50mm rear fenders E-motor type IIs with all collars removed, flipped strut bodies, and STANCE 10k 8k short springs in them(this was some insane ass stupid shit I was fucking with at the time haha). Now everyone else post your shit!!!
Last edited by D*S Dstar on November 22nd 2011, 11:05 pm; edited 5 times in total | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 21st 2011, 5:26 pm | |
| stance gr+pro's stock arms. maxed camber front. 17x10.5+18 rear 255/40 17x9+15 front 225/45 had 20 or 30mm front overs at the time. don't know what size they were cuz i didn't give a shit. they were gay. same exact setup as far as suspension. just went up to 18's all around. 18x9.5-4 225/40 front 235/40 rear. stock metal front, with a roll. rear rolled as well, along with a ghetto pull so i could get to work. wish i had adjustable rears so i didn't have to fuck up the rear qtr panel. then i got a zenki- megan track coilovers, maxed out up front, sagged out in the back. 18x10-1 225/40 front, stock metal, only rolled. 18x10-36 225/40 rear 50mm rear origin overs. yes i know, holy rake, didn't have the car long enough to care to even adjust it. s13- megan tracks, again maxed out front with 2 collars removed sagged rear with collar removed to get low enough stock arms, maxed out camber up front. rolled fenders front and rear. 17x9.75+18 front, +19 rear 225/45 all around rubbed the spring like a bitch in the beginning. same specs as above suspension/fender wise, just threw on 18's. then 18x9.5+15 battles with 215/40 all around. had 6mm spacer out back so 9.5+12 rear. | |
energ Established Member
Number of posts : 549 Age : 35 Location : Bartlett Vehicle : 13.5 Reputation : 7
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 21st 2011, 5:27 pm | |
| also pretty surprised this wasnt started earlier.. my set ups- Stance GR+pros, solid subframe bushings, all circuit sport links, no front sway bar Weds Kranze Shoki 18x.9.5 -6 225/40 Front ~ -3* camber 18x11.5 -18 265/35 Rear ~ -4.5* camber Weds Kranze LXZ 18x9.5 -10 225/40 Front ~ -3.5 camber 18x10.5 -26 235/40 Rear ~ -4.0 camber | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 21st 2011, 10:19 pm | |
| Greddy type-s short stroke coilovers. fronts have tons of room to go down, rears are maxed with spring perches removed. T3 negative camber roll center adjusters (adds 25mm of track and 3* camber on each side) T3 tension control rods. Battle version 4-link. Battle version lateral rod. No traction brackets in these pics. Front: fenders are ghetto flared for steering clearance. 14x8 -12 SSR reverse mesh, 185/60 direzza z1 star spec. -4.5* camber, 0 toe, 2.7 caster. Rear: no fender work. 14x8 -5 SSR Longchamp XR-4, 185/60 Kuhmo ecsta platinum touring 0* camber, 0 toe. [/img] [img]
Last edited by D*S LongGrain on November 23rd 2011, 12:32 pm; edited 1 time in total | |
YELLOW Post Enthusiast
Number of posts : 1444 Age : 35 Reputation : 7
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 22nd 2011, 11:03 am | |
| Stock Front Fender Roll Rears Rolled w/ Bat Stance GR+ True Type Stock Arms Will edit with alignment specs when I find the sheet. Enkei RPF1 18x9.5 +0 225/40 F 18x10.5 +0 255/35 R Work Equip DDC 18x10 +3 235/40/18 F 18x10 +3 235/40/18 R | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 22nd 2011, 3:27 pm | |
| Since Tomy doesn't remember my flush cars... may as well since I already found these pics on my FTP AW11 D2 coilovers with flipped lower mounts and removed collars. No arms. F: Work VS-XX 15x8 +12 205/50-15 RT615 R: 15x8 -8 Kosei K1 (25mm spacer) 205/50-15 ZE512 I don't remember alignment specs, but it was 0 toe all around, and about 2.5 degrees of camber I think ZZW30 HKS Hipermax II, Megan rear toe rods F: 16x8 +42 Volk TE37 205/40-16 DZ101 R: 16x8 +17 Volk TE37 (25mm spacer) 205/45-16 DZ101 I'll edit with alignment specs when I find the paper. | |
Steve Established Member
Number of posts : 716 Age : 30 Location : Chi-burbs Vehicle : S14 & JZS161 Reputation : 4
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 22nd 2011, 3:44 pm | |
| Stance GR+ Stance RUCA & Toe 17x9j+22 (20mm spacer -2 effective) 225/45 Star Specs F 17x10j+18 235/40 Fed 595's R -2*F -4*R 0 toe Stock caster Picture before spacer: | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 22nd 2011, 4:10 pm | |
| Yeaaahhhh were throwin down in this bitch already. | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 22nd 2011, 6:52 pm | |
| I can get down with this shit. Mustang reps 17x9-11 up front and 17x10.5+12 rear here they are with the front using 215/40's and rear had 235/40 switched up rear tires to 225/45 with Enkei RPF1's 17x9-13 Front, 17x10-2 Rear. Front tires are 205/45 rear tires are 235/45 Advan TCII (Still working out fitment as I go) Front: 215/45/17x9.5+14 w/25mm spacer (17x9.5 -11) Rear: 215/45/17x9.5+14 w/25mm spacer (17x9.5 -11) Still need to Lower some more. Thinking of moving up to 30-35mm spacer for the rear. As far as suspension goes. All ive really had this whole time was Stance GR+Pros. not full low yet. Max (-) camber on C.Plates on front coilovers. Ive never gotten an alignment before either. Nor have I any idea what my actual camber, toe, etc. etc. etc. is. I now have Multi-Link pieces to throw on so ill start fucking with alignments and fartblossom and what not, next year. | |
Bliz Khalifa Established Member
Number of posts : 886 Age : 37 Location : House of Love Reputation : 20
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 23rd 2011, 11:32 am | |
| Powered by max coils Powered by max Arms 17x9.5j+18 (10mm spacer) 235/40/ maxxis maz1 17x10j+18 (10 mm spacer) 235/40 maxxis maz1 -2*F -3*R 0 toe Stock caster | |
DAELEN Forum Frequenter
Number of posts : 272 Age : 34 Location : It's 11PM, do you know where your pants are? Reputation : 14
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 23rd 2011, 12:11 pm | |
| Stance GR+ With room to go All stock everything else. Front: 17x9 + 15 215/40/17 Federal 595 Max neg Camber Back: 17x9 -15 215/40/17 Federal 595 Lots of toe in, lots of neg camber. Stance GR+ with room to go JTP Knuckles GP Sports angle kit Battleverrsion Toe and camber arms out back Front: 18x9.5 -8 215/40/18 Federal 595 Max Neg Camber Rear: 18x9 -10 225/40/18 Can remember what tires Toe in, neg camber. T3 Front coilovers Cut spring from an 80's camaro out back, with a front shock off a 90's F150. Front: 15x8.5 -8 195/45/15 DZ101 Like -1 Deg camber Back: 15x9 -18 205/50/15 DZ101 I will see if I have more pictures of my older cars at home. Never really took pictures of shit before the FC. | |
Olly Fucking Noob
Number of posts : 69 Age : 40 Location : New Zealand Reputation : 2
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 23rd 2011, 7:17 pm | |
| Wedsport SA60M HSD coilovers | S14 LCA | Rolled Rear | Lipped front Front: -5.5* 18x9+23 w/ 8mm? slip on 225/35 NS2 Rear: -4.5* 18x10+20 225/40 Neutron | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 23rd 2011, 8:29 pm | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 23rd 2011, 8:55 pm | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 24th 2011, 10:30 am | |
Pepe Pepe 9-Time Taco Bell World Champion
Number of posts : 450 Age : 34 Location : Hoffman Estates Vehicle : Lincoln LS/180sx Reputation : 8
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 24th 2011, 11:17 am | |
| Basic shit 16x8 sportmax 195-50-16 is what i ran? Stance gr+ (blown) Never got aligned at this stage Battles 18x9.5 all around Same blown coilovers Still no alignment Cr Kai Front 17x9 +17 First ran 215/45/17 rubbed way to much at the height i wanted to be at up front Currently 205/40/17 works, but I'm not diggin it anymore Stance Gr+pro Coils sagged and one collar removed Camber -3.0 Toe 0 Caster 7.5 Rear 18x9.5 +12 225/40/18 Stock arms sagged and both collars removed with helper | |
Teo Forum Frequenter
Number of posts : 433 Age : 35 Location : North IL Vehicle : Nissan Stanza Reputation : 2
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 24th 2011, 9:24 pm | |
| Those old coils weren't THAT blown.... They hold up my 3400lb turd limo and it feels better than my old coupe ever did on brand-new spec.
<3 the new height, btw. | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 25th 2011, 9:58 am | |
| Those were one of the first sets that were made. Old as fuck.
Love my height. But I'm raising the front as going with a fatter tire. Rear stays the same. | |
Matej Oh, the IRONY!
Number of posts : 476 Age : 36 Location : Kansas City Reputation : 13
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 26th 2011, 2:48 pm | |
| 18x9 +0, 215/35 18x10 -13, 225/40 Megan Streets with Swift Springs. S14 FLCA. Do not know anything about camber and such. | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 26th 2011, 5:07 pm | |
| First cool set-up if cool at all. Sportmax full slam on D-drug coilovers. Hanbai DT05r 17x8.5 +25 fronts +25mm spacer 17x9.5 +35 rears +25mm spacer Looked pretty cool on stock metal ( 215/40F 235/45R) Same set-up with more overs and spacers Just added a 50mm spacer in the rear with Origin overs 30mm I think. Also threw in a 10mm slip on the front and rolled the front render. Then had this as my daily set up. Same wheels and spacer set-up, just with a really aggressive pull all around. Really aggressive ride was the name of the game. 30mm D1 replica fenders 35mm Works aero rear overs 215 45 all around 40mm front spacers 50mm rear spacers Effective 17x8.5 -15 front and 17x9.5 -15 This my current shit. Work XT-7 17x9+15 18x9.5 +12 25mm front spacer 50mm rear spacer Origin 20mm front fenders, 50mm rear fenders Megan Tracks fully slammed. I think ive only changed wheels twice.
Last edited by D*S Trucky on November 27th 2011, 7:01 pm; edited 1 time in total | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 26th 2011, 5:38 pm | |
| ^ Your fronts are 9sss, Arent your rears 18?
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 26th 2011, 6:36 pm | |
| Are you running a 215 45 up front? | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 27th 2011, 7:02 pm | |
| To be honest I don't even remember my exact size's. Im probably really wrong. | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 27th 2011, 9:58 pm | |
| niggas up in here just making shit up. Typing whatever numbers pop off in his brain haha. | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. November 28th 2011, 2:21 am | |
| Haha. He got almost every single number right besides his wheel height. The thing with Trucky is he dont give a fuck about numbers as much as everyone else, he gets in there and works with it in actuality and fucks with it till its perfect, his cars stay low low and peekin out the fenders. | |
| Subject: Re: The CA240SX Wheel Fitment and Ride Height thread. | |
