| Higher boost sputter | |
+3ka24orce Nachtmensch Brad Feinstein 7 posters |
Brad Feinstein Fucking Noob
Number of posts : 82 Age : 34 Reputation : 0
| Subject: Higher boost sputter August 23rd 2011, 11:26 pm | |
| So i've had this issue on and off since I bought the car last spring. When I am boosting anything over about 8psi my car starts to sputter/pop. I can hold the throttle steady just under 8psi and it accelerates perfectly normal, and it starts and idles just fine as well. I had the spark plugs out and set the gap to around .032". Just a dumb thought, the coils dont ground out thru the bolt that holds them down do they? Because one coil has a broken off bolt in the valve cover and that has been my only thought to what could be causing this.
For the last few weeks it has been doing this all the time...I was planning on signing up for the event on the 9/4 but can barely break the tires loose like this! | |
| Subject: Re: Higher boost sputter August 23rd 2011, 11:32 pm | |
| coils ground through the wiring. Sounds like it's running lean. Add more fuel and see what it does. | |
| Subject: Re: Higher boost sputter August 24th 2011, 9:28 am | |
| I have no way to add more fuel, its an all stock sr setup. | |
| Subject: Re: Higher boost sputter August 24th 2011, 10:54 am | |
| Yeah, change that.
You're stuffing more air into it, stuff more fuel. | |
| Subject: Re: Higher boost sputter August 24th 2011, 10:57 am | |
| I guess I just dont see why it would need more fuel, unless something wasnt operating properly..(injector, fpr, pump). It is stock boost, the only thing not stock to the sr is probably the intake!
What would be the easiest way to get more fuel? I have a walbro. | |
ka24orce Ace Combat Driver
Number of posts : 372 Age : 40 Location : Riverside Vehicle : 180sx, Reputation : 11
| Subject: Re: Higher boost sputter August 24th 2011, 11:13 am | |
| Is the intake tube that stock rubber one? Those like to collapse on themselves | |
| Subject: Re: Higher boost sputter August 24th 2011, 11:51 am | |
| this tells me you aren't at stock boost - Brad Feinstein wrote:
- SWhen I am boosting anything over about 8psi my car starts to sputter/pop.
gOtPUrPL3 Post Enthusiast
| Subject: Re: Higher boost sputter August 24th 2011, 12:23 pm | |
| might have a boost leak.make sure all your couplers are tight on the inter cooler and that none of them have any damage. | |
| Subject: Re: Higher boost sputter August 24th 2011, 9:33 pm | |
| Without the solenoid that usually doesnt come with the sr20 motorsets the boost is at 11 psi. I will be double checking couplers tomorrow. The intake tube is an aluminum one, I replaced that a while back thinking that was the problem. | |
| Subject: Re: Higher boost sputter August 24th 2011, 9:58 pm | |
| no, without the solenoid, boost is 7psi (wastegate spring pressure). With the oem boost solenoid its 10. Its impossible for it to be the other way around, as electronic means cannot lower boost lower than the wastegate spring's stiffness.
and again, theres no reason you should need to tune at that boost level from a stock turbo. I used stock s13 injectors, MAF and ECU with cams and a t28 at 16-18lbs of boost and never had a single issue. Stock ecu and injectors can handle a t25 at 14+psi without a complaint, so this is a different.
I forget, does your car have a boost controller? or maybe check for an hks wastegate actuator or something, because you SHOULD be boosting 7psi natively, not 10 or 11.
check for boost leaks as well, like dabs said. | |
| Subject: Re: Higher boost sputter August 25th 2011, 8:38 am | |
| No we took the boost controller out. Ok so I had the 2 mixed around, it is boosting around 10-11 right now (or trying to). | |
| Subject: Re: Higher boost sputter August 25th 2011, 10:57 pm | |
| Well today I found a vacuum hose going from the valve cover to right behind the engine cracked in 3 places from being too hot. Got that piece replaced and now I have a high idle, and it still sputters the same. | |
rc1honda Fucking Noob
Number of posts : 82 Age : 42 Reputation : 4
| Subject: Re: Higher boost sputter August 27th 2011, 1:45 pm | |
| Bring your plug gap down to .28. Change the idle via adjustment screw. | |
| Subject: Re: Higher boost sputter October 9th 2011, 10:57 pm | |
| Got it....was either the fuel pump relay power wire or the injector o-rings...Was so excited to fix both that I forgot to test in between! | |
| Subject: Re: Higher boost sputter October 10th 2011, 5:38 am | |
| Nice. Does that shit rip now? | |
| Subject: Re: Higher boost sputter October 10th 2011, 1:58 pm | |
| Yes sir, like a raped ape! lol | |
| Subject: Re: Higher boost sputter | |
