| Author | Message |
Berzerker Light Duty Poster
Number of posts: 194 Age: 26 Reputation: 0
 | Subject: Boost gauge install August 5th 2007, 5:44 pm | |
| Hey any1 got a pic of the fuel line that i should put in the T for the boost gauge...? |
Number of posts: 2230 Age: 99 Vehicle: s14 Reputation: -1
 | Subject: Re: Boost gauge install August 6th 2007, 11:35 am | |
| what kind of boost gauge? mechanical or electric? |
Number of posts: 1426 Age: 72 Vehicle: S13 Garage Slut & S14 Daily Whore Reputation: 2
 | Subject: Re: Boost gauge install August 6th 2007, 1:52 pm | |
| you going to hook up a boost gauge to a fuel line??? |
 | Subject: Re: Boost gauge install August 6th 2007, 7:46 pm | |
| Mechanical, and on the direction it states I have to put a T in the hose that goes from the fuel regulator to surge tank, i think i see the fuel regulator but there is a few different hoses , i was wondering if any1 got a pix of the hose i need to cut and put a T fitting in it. |
gOtPUrPL3 Post Enthusiast
Number of posts: 1403 Age: 25 Location: 60411 Vehicle: 240sx Reputation: 16
 | Subject: Re: Boost gauge install August 6th 2007, 8:03 pm | |
| just T off the line that goes to the bov and hook it to that |
 | Subject: Re: Boost gauge install August 6th 2007, 8:10 pm | |
| ATM i got nothing that goes to the BOW, im trying to figure out if I can leave the bow open.. |
 | Subject: Re: Boost gauge install August 6th 2007, 8:38 pm | |
| get on the chatbox ill help u out |
profpin Light Duty Poster
Number of posts: 119 Age: 40 Location: southside chicago Vehicle: sil 80 Reputation: 0
 | Subject: Re: Boost gauge install August 7th 2007, 5:47 pm | |
| theres some vacuum ports by your throttle body.. you can tee it off on one of the ports.. |
 | Subject: Re: Boost gauge install August 7th 2007, 8:23 pm | |
| missed the fuel line comment. ^ way is better. |
 | Subject: Re: Boost gauge install August 7th 2007, 10:54 pm | |
| Yeah i know but there is alot of those hoses there, tomarow ima have a better look i guess... |
 | Subject: Re: Boost gauge install August 8th 2007, 12:43 pm | |
| | Berzerker wrote: | | Yeah i know but there is alot of those hoses there, tomarow ima have a better look i guess... |
just pick one.. thats all.. dont be scared..  |
 | Subject: Re: Boost gauge install August 10th 2007, 10:13 am | |
| I tried 4 line yesterday none of them showed me any boost, I don't know wut fking lines to cut any more, Or should i T in the Line that goes from turbo compressor to the actuator for boost readings? but that would not show the lag im guessing.
Also i got a HKS actuator, and I have now idea wut PSI im set at grrr....
And also this might be a sutpid question but this is my 1st turbo car, when i rev the engine lets say to 4k rpm should the turbo spool up too in nutral and BOV go off? Because i revved it up to 4k yesterday but dint hear anything from the BOV. |
 | Subject: Re: Boost gauge install August 10th 2007, 10:56 am | |
| reving it up in the parking load will not get you boost. there needs to be a load on the engine. |
 | Subject: Re: Boost gauge install August 10th 2007, 5:31 pm | |
| Ahh revving in first girl would do the trick  well i dunno still trying to figure out how to instal zzzz.....some1 help plz.... |
 | Subject: Re: Boost gauge install August 10th 2007, 6:18 pm | |
| | profpin wrote: | | theres some vacuum ports by your throttle body.. you can tee it off on one of the ports.. |
^try that....as profpin stated earlier. make sure your line isnt kinked otherwise it wont read. |
 | Subject: Re: Boost gauge install August 10th 2007, 9:38 pm | |
| From the fuel regulator to intake mani, i Ted in there it reads -20 psi lol until i hit gass then it goes to 0, that is what the instructions stated, tomarow ima put a fitting in my cold pipe and hook up one vaccum line to it and put a T in that vaccum line... |
czr240 Fucking Noob
Number of posts: 17 Age: 26 Location: Cicero, IL Vehicle: 1998 240sx Reputation: 0
 | Subject: Re: Boost gauge install August 13th 2007, 1:51 pm | |
| do you mean 20 hg? vacuum? if its on the twenty under the 0 then its reading vacuum, thats what you want at idle. and as you accelerate it goes up to zero and passed it when you boost. . . if so you have it hooked up right |
 | Subject: Re: Boost gauge install August 13th 2007, 4:17 pm | |
| O fuck i did then lolx, i took it out, but i ordered a Vaccum Block from JGS ima put that in the Brake booster line, and have boost gauge and BOV to that... |
