kidynomite Fucking Noob
Number of posts : 69 Age : 37 Reputation : 0
| Subject: TC Rods; Toe Arms; SR Bellhousing; HKS Turbo Timer May 21st 2011, 12:20 pm | |
| Toe Arms $75 TC Rods $150 Both arms Peak, the toe arms are bent from being low, still work fine, peaks are strong. If you realy wanted you could probably get a replacement rod from them TC rods are good condition, one bearing is brand new S13 5 speed driveshaft took out working just fine $65 SR Bellhousing $50 Turn a KA trans into an SR with it (still connected to a broken trans, which you can have) HKS Turbo Timer, I dont remember what I did with the wiring, but I spliced into it for something, still works - $40 | |
