| Subject: Re: s14 ka24de March 17th 2007, 8:02 pm | |
| Well the common problem with leakdown tests is that the engine ends up moving because of the shop air thats being put into the cylinder. This forces the piston down and turns the crankshaft. When this happens you cant get a good reading of what the leakage will be. This can be remedied by finding a way to hold the crankshaft from moving. Usually a 15-20% leak is acceptable. Other than that my engine doesnt burn oil, or leak anything else. It does have the typical timing chain rattle but that can be fixed when doing a rebuild. Its seen better days and id probably do a rebuild if youre serious about boosting or making more power. Ill post when the time comes to sell it. Good luck finding a good one though. | |
Ruckus1027 Light Duty Poster
Number of posts : 108 Age : 36 Location : lombard Vehicle : avenger, 240sx Reputation : 0
| Subject: Re: s14 ka24de March 17th 2007, 8:31 pm | |
| ah ok i was thinking vacuum test....haha i was thinkin of something else...but yea..so ur not selling ur motor yet??...man...thanks for getting my hopes up....haha jk...well if im still looking for a motor wen you sell then ill definitely consider it....thanks tho | |
