| Legend of LongGrain. An AE86 success story. Part 1 | |
+63Pharmaceuticals drftx Maikeru KappS14 jayys05 rouwraip ilia VisionShift mrkan hoffman240 zerepdivad Steve Specter ferrarisx whiterps13 Vegas13 revgasm_josh hs13kls Bliz Khalifa blklabel44 YELLOW ill roller fresheg6 Trucky's bitch. Brad Feinstein Felix Da Housecat borracho JAYYS Cyclohexyl Coupe Oscar TunerRSI Dirty Dee D*S Tomy Guns mikemadison_09 rwdbandit Curtis DeAngelo Nelson II RacerX D*S Dstar DAELEN s14rob Jay SIMON D*S Roski skyvia686 dorikin717 shortyman4065 Los Vlados Locos altavelocidad David his180sx D*S Homeboy. Matej D*S Trucky FusionR300zx evanger ka24orce D*S Dave Stab Master Sharson Adrian_S13 sad Nachtmensch RAD MIKE Circa 3006 DJ Longdick 67 posters |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 1st 2013, 9:50 pm | |
| You mean the x bars? Or the lateral bars that come down from the hoop to the floor?
Most cars have those going to the same point as the x brace, connecting to the rear shock towers, However corolla shock towers are not load bearing or structural, so we had the lateral bars go to the frame rails, and the x-brace tie to the shock tower bar. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 2nd 2013, 1:36 am | |
| Lateral bars. I'm more about aesthetics of the cage. But it's cool that it ties into the frame. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 2nd 2013, 10:53 am | |
| So am I. i think it looks rad having more than one plane of bars going across the quarter windows. I definitely dont think it would have looked cooler having those bars go to the shock towers like the rest of them.
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 9th 2013, 11:05 pm | |
| got some more parts. /gay race car parts. Going down with satty this weekend to put in work. fuck waiting around. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 12th 2013, 1:45 pm | |
| Updates from this weekend. Started off answering a desperate cry for help. My bro (satty) needed a stout towing vehicle to move some heavy crap. Honda fit to the rescue, hauled this 600lb 2jz and a trans without even knowing it was there. This thing is awesome at hauling engines. Got to DW and my engine was in the bay taking measurements and getting mocked up for mounts. I dont know why everyone has such an issue fitting the motor and being able to close the hood. setting it on the subframe revealed that it should not take much work, but there was some oil pan clearancing that could be done to help out. Upon taking the lower pan off, I was relieved to see that the engine looked brand new inside, not even oil stained. Then off came the upper pan. An equally brand new looking rotating assembly. I did not take a "before" picture of the oil pan, so here is one from google. you can see on the bell housing side where it bubbles up to match the transmission. This serves no purpose really other than to probably add some bracing. Somewhere in here satty's retarded cousin showed up to pay vinny to put aftermarket wheels on his car, and upon his first test drive, he made it about a block from the shop and tried to get his ken block on, it worked. So that was a minor setback for the day, having only a honda fit (with a 2j in it) and a jetta to try to pull it out with. (succeeded though) And here is a cool picture of another customer's supra at vinny's, thing is COOL. my front suspension was back on after lowering it another inch so i set my fender on it and its pretty low (mind you, this is with no engine, or anything else in the bay.) back to the oil pan. we chopped the rear part off, leaving the trans mating flange and welded in a plate (not really necessary, but it will stop dirt and grime from getting in the bell housing. Vinny did not want me to take a picture of this because it was not finished here, but I did anyway. And then Ironically, I forgot to take a picture of when it was finished, so that's all you get. Here is a cool picture of the top of the upper pan, its very race car like. Meanwhile satty was plasma cutting and grinding on my subframe. and came up with this. it looks very nice. It will look like this when it is finished. We made the parts for the mounts too, now its just a matter of assembling the engine, bolting on the trans and putting it back in the car to tack the mounts in place for final welding. we also did some other things like cut out my shifter hole to (hopefully) accomodate the long ass 6sp trans, it might need to go even further than where we cut it, but we'll see. Moral of the story is the beams 3s is built like a brick shit house (whatever that means). Thing has oil squirters even though it is not turbo, has huge oversized beefy rods, crank is machined and balanced, Oil pan is reminiscent of a dry sump configuration straight from the factory with tons of bracing, Not to mention the 11.5:1 compression, full titanium valvetrain, etc in the top end. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 17th 2013, 11:31 pm | |
| since no one cares. This thing was scraped up, almost scraped through in one spot (i think it was just from being dragged on the foor at some point) 3/16" skid plate and shifter bracket is not bolted on properly in this photo, it will be about 2" further forward than this in real life, you can see the bolt holes where it should be bolted in the photo. | |
D*S Tomy Guns DS! DS! DS!
Number of posts : 817 Age : 36 Reputation : 19
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 18th 2013, 11:38 am | |
| Man, this shit is going to look fucking crazy when it's done. I like that plate u welded on ur oil pan. Fuck pot holes. | |
evanger Post Enthusiast
Number of posts : 1299 Age : 31 Location : Not Chicago Vehicle : AA63, S14 Reputation : 16
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 18th 2013, 12:00 pm | |
| I'd give up anything to be able to have a car like this. Being a Toyota-nerd, this is exactly how I want an 86 to be. OG street look on the outside, serious business on the inside. Two fucking thumbs up. | |
dorikin717 Established Member
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 18th 2013, 9:53 pm | |
| I cant wait to see this thing in action, awesome build man! | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 18th 2013, 10:26 pm | |
| That weld on skid plate is bomb as fuck. This car is a spaceship. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 19th 2013, 12:01 am | |
| thanks dudes.
as expected, not nearly as much got done today as we had hoped for.
hopefully the engine/trans will be mounted for good tomorrow, or a year from now, who knows. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 19th 2013, 6:25 pm | |
| Keep ya head up player rice! I know how it feels. I know it sucks not driving what you are building.
Shits definitely looking up though. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 May 26th 2013, 2:42 am | |
| Got some more parts and did some more things. kill switch Lug nuts battery hold down (not actually mounted to car yet) helmet stuff and things engine mounts | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 June 15th 2013, 3:16 pm | |
| engine mounts are finished | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 June 15th 2013, 9:34 pm | |
| Nice. Is BEAMS setup significantly taller than 4A? Those bad boys are low mount as fuck. Sweeet. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 June 16th 2013, 2:27 am | |
| Yea, its way taller, by like 4 or 5 inches iirc (with the engine cover on). Creates huge hood clearance problems. Most people just space their subframe down like 2", but i'm not really a fan of that. nerd roll center shit aside, i'd rather have my subframe in as close to the stock location as possible. With this setup i should be able to close the hood if we trim the hood skeleton. in other news: mil spec chassis harness is just about finished. Mark just sent me these pics tonight. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 July 8th 2013, 9:05 pm | |
| I got ^^^ that stuff. engine mounts are done engine sits in there nicely Trans mount is also done, had to do a full custom piece for this. And mocking up radiator radiator is custom as well, took a CX racing ae86 unit and shopped the inlet, outlet and mounting tabs off of it, welded the holes shut, flipped it around and welded them back on the other side, have to do some mounts and fab up an upper support. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 July 8th 2013, 9:33 pm | |
| Looks good. I'd remove that paint job on the radiator though. ETA? | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 July 8th 2013, 9:37 pm | |
| clubfr jam or die trying.
in my head it is do-able, but who the fuck knows.
In my head no star bash LAST year was doable, and i was very wrong.
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 July 12th 2013, 9:51 pm | |
| - Nachtmensch wrote:
- Looks good. I'd remove that paint job on the radiator though. ETA?
But really thats minimal, I know you've been dropping obscene loot on this in the past year or so, so really I'm just rooting for you to finish it so I can suck your dick about it. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 July 14th 2013, 12:05 pm | |
| thanks man.
the radiator was already like that. I had bought a koyo that I had planned on modifying, but vinny had this one already modified for his 20v car, all brand new otherwise, and the work was already done, he said I could have it, so i sold the koyo. I dont care about the logo really. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 August 8th 2013, 3:17 am | |
| some updates from today. I finally got to go down and do some work on the car. First we modified the thermostat housing so that the water outlet faces forward instead of sideways. should make for easier radiator hoses. The top one, well. I'd say it lines up pretty well... It was refreshing somewhat to see the car with a fender on it, made it look less like a pile of shit. welded in a "bomber" bar for no reason really other than we could. My headlight backing plate things (whatever that part of the core support is called) were all mangled and rusted to shit so we decided to take them off, one of them was welded on so poorly we smacked it with a hammer like twice and it came off. If any of you remember my S13 build, this part is called "not learning from my mistakes" So we made a new upper tie bar for the core support. This thing is actually a lot closer to running than it looks. thats all for tonight. Thanks for reading. | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 August 8th 2013, 7:32 am | |
| Man, it looks like u still got a ton of shit to do to it. Shit looks good though. I need to come down there to check this crazy shit out in person, King cobras on me. | |
Bliz Khalifa Established Member
Number of posts : 886 Age : 37 Location : House of Love Reputation : 20
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 August 8th 2013, 11:52 am | |
| I love all the small detail's
It makes it even more awesome | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 August 8th 2013, 11:53 am | |
| Subject: Re: Legend of LongGrain. An AE86 success story. Part 1 | |
