| Radaitor trouble | |
+8ChicagoS14T demian112 D*S Dstar D*S Roski mikemadison_09 Jay RAD MIKE Circa 3006 scubasteve 12 posters |
scubasteve Light Duty Poster
Number of posts : 148 Age : 37 Location : Chicago, IL Vehicle : 92 Nissan 240sx Reputation : 0
| Subject: Radaitor trouble April 27th 2009, 10:20 am | |
| Okay, so here's the issue. My radaitor blow out the other night and I got a new one. I installed and filled it up now my car won't start. I think I didn't fill it properly. Any ideas??? | |
| Subject: Re: Radaitor trouble April 27th 2009, 10:21 am | |
| that shouldnt have anything to do with your radiator... | |
| Subject: Re: Radaitor trouble April 27th 2009, 10:27 am | |
| My car ran prefect before my radiator blow out and even still started up and ran after the radiator blow. | |
| Subject: Re: Radaitor trouble April 27th 2009, 10:53 am | |
| what all did you disconnect? does your car crank and what not or just nothing at all? | |
| Subject: Re: Radaitor trouble April 27th 2009, 11:35 am | |
| your mechanic is a moron, fire him. | |
mikemadison_09 Forum Frequenter
Number of posts : 267 Age : 32 Location : chicago Vehicle : 89 coupe Reputation : 0
| Subject: Re: Radaitor trouble April 27th 2009, 12:02 pm | |
| are all the vacuum lines connected to ur intake? | |
D*S Roski DS! DS! DS!
| Subject: Re: Radaitor trouble April 27th 2009, 5:45 pm | |
| did you do a sexy dance prior to starting the car?
that ALWAYS turns my car on | |
| Subject: Re: Radaitor trouble April 27th 2009, 6:06 pm | |
| Replace your coolant temperature sensor. Mark my words. | |
demian112 Forum Frequenter
Number of posts : 494 Age : 34 Location : joliet, Illinois Vehicle : 1992 240sx vert Reputation : 3
| Subject: Re: Radaitor trouble April 27th 2009, 6:47 pm | |
| - President D*star wrote:
- Replace your coolant temperature sensor.
Mark my words. that sounds like a good idea, but it will still start even if the CTS is fucked up. no? | |
| Subject: Re: Radaitor trouble April 27th 2009, 6:51 pm | |
| No. Dont ever doubt me. The last time your dumbass did, you put gear oil in your fucking clutch master cylinder. | |
| Subject: Re: Radaitor trouble April 27th 2009, 6:54 pm | |
| HAHAHAHAHAHAHAHA, that is because i never did any kind of clutch work, and i asked the auto part guy and he gave me that shit... lol | |
| Subject: Re: Radaitor trouble April 27th 2009, 6:57 pm | |
| I had already told you what to do. But you decided to listen to the faggot at NAPA. Serves you right. | |
| Subject: Re: Radaitor trouble April 27th 2009, 7:00 pm | |
| lol, ok lets forget that shit..... | |
| Subject: Re: Radaitor trouble April 27th 2009, 8:34 pm | |
| Did your car overheat? Did you pop your head gasket? Does your engine crank? Give us more to work with. | |
| Subject: Re: Radaitor trouble May 3rd 2009, 1:17 pm | |
| I followed this link http://forums.nicoclub.com/zerothread?id=263723, my radiator busted just like the one in the link. All my lines/holes are connected back to the intake and radiator. My friend said it sounds like it has a lot of air in it. I tired top it off to get the air out but no luck. | |
| Subject: Re: Radaitor trouble May 3rd 2009, 1:47 pm | |
| topping it off would get the air out. you gotta bleed it out. | |
| Subject: Re: Radaitor trouble May 3rd 2009, 10:17 pm | |
mrkan Established Member
Number of posts : 709 Age : 35 Location : Jo-li-et Vehicle : Dirty E30, Decent E39, Gay S13 Coupe Reputation : -7
| Subject: Re: Radaitor trouble May 4th 2009, 8:49 am | |
| So you fixed the problem?
after a coolant flush i would always fill the radiator up with coolant and the jack the front of the car up and run it, wait until you see no more air bubbles,then fill the radiator up as necessary. this would make the trapped air rise to the top and out of the engine block and make more coolant go in. just an FYI tis all. | |
matrix232 Light Duty Poster
Number of posts : 116 Age : 44 Location : Chicago Vehicle : 91 240SX Reputation : 0
| Subject: Re: Radaitor trouble May 15th 2009, 12:36 am | |
| my Radiator blow in the same place. do they all fail in the same place? | |
| Subject: Re: Radaitor trouble May 15th 2009, 12:54 am | |
| Ur car should start, unless u disconnected something.
Ur suppose to fill to the top, while car is off, then once the car starts u remove the bleeder screw and top it off while the car is running, u know all the air is out once u get a stream of water free of bubbles coming out of the bleeder hole.
Once my car had an air bubble right where the CTS was at and my car wouldnt start, had to remove it to release air. | |
| Subject: Re: Radaitor trouble May 16th 2009, 6:08 pm | |
| where is the bleeder screw? - Master Trucky wrote:
- Ur car should start, unless u disconnected something.
| Subject: Update on Radiator trouble May 17th 2009, 3:26 pm | |
| For those who haven't read the previous "Radiator Trouble" here's a recap. My radiator blow out and I replaced it. Drove to the gas station three blocks away (turn the car offf), then went back home and chilled for awhile(turn the car off again). Then tried to go to the store, but the car wouldn't start. Many ppl on here have given me good reason why the car isn't starting but, today I found that there's a connector that is not pluged up and some wires that look cut. I have some pics, please help or give any postive feedback. | |
| Subject: Re: Radaitor trouble May 17th 2009, 4:07 pm | |
| Subject: Re: Radaitor trouble May 17th 2009, 4:08 pm | |
| Sorry for the extra large photos. | |
| Subject: Re: Radaitor trouble May 17th 2009, 7:35 pm | |
| Still having issues? You check your starter? My starter fried out. I think coolant from my heater core was leaking on it. I replaced my starter and so far so good. | |
| Subject: Re: Radaitor trouble | |
