 Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!!
nismokid
Number of posts : 3
Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Empty
PostSubject: Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!!   Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Icon_minitimeFebruary 12th 2009, 4:17 pm
i have lots of stuff to get rid of. starting a new build. here are my parts.
ALL PRICES ARE OBO!!!
NO LOW BALLING!! I JUST WANT TO SELL MY PARTS. PLEASE KEEP YOUR NEGATIVE COMMENTS TO YOURSELF!!! THANK YOU!!!
IF YOU WANT TO BUY IT ALL OR A COMBO OF PARTS I CAN WORK ON THE PRICES!!! I CAN BE CONTACTED AT 847 847 8674 OR EMAIL SIRGUY94@YAHOO.COM
BLOCK AND HEAD ARE TOGETHER STILL. IF YOU LIKE BOTH I WILL LEAVE TOGETHER. THANKS
Short Block- $3000 (10 Min Of Idle Time)
Darton Sleeves
CP 9:1 89mm Pistons
Crower Rods
Lightened and Balanced Crank
Then Rotating Assembly Was Balanced Internally
Clevite Bearings
ARP Main Studs
Cylinder Head- $1300
Tomei Valve Springs
Toda Cam Gears
Tomei Solid Lifters (Shimmed By Mazworx)
HKS 264 Step 3 Cams
Crower Retainers
ARP Cam Bolts
Light Port And 3 Angle Valve Job
Parts-
USED ARP Head Studs $75
Greddy Oil Pan $200
ATI Dampener $350
OS Giken Twin Disc W/ Through Out Bearing $450
S13 Trans W Nismo Pivot Ball and Short Shifter $325
AEM EMS 1601U W/ AEM Air Intake Temp Sensor/ AEM 3.5 BAR Map Sensor/ And AEM Boost Solenoid $1250 (USED But Worked Flawlessly)
HKS Twin Fire Ignition $250
Nismo Slave $75
JGY Fuel RAil W/96lb. Injectors $225
Knock Off Greddy Intake Manifold W/ Q45 Throttle Body $325
Polished Valve Cover $125
Powder Coated Black Valve Cover $40
NEW Front Cover $180
USED Front Cover W/ New Front Main Seal $65
NEW 90mm Mazworx Head Gasket $180
Coil Packs $50
Upper Oil Pan Ground Down For Main Stud Clearance $50
Sr20det Starter (Works) $45
Sr20det Alternator W/ Bracket $50
Black Top Oil Pickup $20
Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Picture036
Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Picture030
Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Carandtruck049
Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Carandtruck043
Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Carandtruck059
PostSubject: Re: Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!!   Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Icon_minitimeFebruary 12th 2009, 10:04 pm
Fuck that block and head setup is SWEET.
PostSubject: Re: Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!!   Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Icon_minitimeFebruary 13th 2009, 12:09 am
seriously amazing
PostSubject: Re: Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!!   Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Icon_minitimeFebruary 13th 2009, 11:54 am
whut's upp buddy.. good luck with the sale.
nismokid
Number of posts : 3
PostSubject: Re: Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!!   Fully Built Sleeved Sr20det OS Giken AEM EMS LOTS OF STUFF!! Icon_minitimeFebruary 13th 2009, 2:27 pm
thanks fusion!!
any body need some goodies to make your car have 600rwhp. need this stuff gone
» Buy a fully built racecar S14.
» ka24de fully built engine for sale AMS
» 1992 coupe fully built suspension
» LOTS A STUFF I NEED GONE!!!!!!!!!!!!
» FS/FT: 1989 240SX Fully built SR20 .40 over gt28 412hp/19
