| Compression issue... | |
+5Stab Master Sharson hs13kls [ynot] Nachtmensch D*S Trucky 9 posters |
| Subject: Compression issue... January 4th 2009, 11:26 pm | |
| Allright well i just got back from Texas, and now i need to get the coupe up and running, for a trip down there and i mean soon... Well here is my problem, I have and S13 sr, basic mods, FMIC, 3in exhaust, nothing to big... Before i left i was doing some routine maintanance, and i realized that there was a milky residue under the oil cap, so i decided to do a compression test and i got 120-60-120-120, i think its the head gasket, since its mixing oil and coolant, but if anyone could provide a second opinion that would be great, since im gonna start to take it apart tomorrow.. | |
| Subject: Re: Compression issue... January 5th 2009, 12:01 am | |
| sounds like a HG, like you said. compression numbers are also a little low, most likely due to an old engine though. | |
| Subject: Re: Compression issue... January 5th 2009, 12:20 am | |
| Thats what i thought Kevin, i also wanted to do the piston rings, but im a little short on time... I think im gonna do a Cometic HG since i could pick it up locally from TF and ive heard good things about them... | |
[ynot] Light Duty Poster
Number of posts : 120 Age : 35 Location : chi-town Vehicle : 91 240sx hatch Reputation : 1
| Subject: Re: Compression issue... January 5th 2009, 1:31 am | |
| its your head gasket for sure but i would also think of changing the rings well your at it.. you never know when they might go and then you gotta rip apart the engine again... just something i would do... | |
| Subject: Re: Compression issue... January 5th 2009, 7:01 am | |
| dont forget to check the block for being flat. | |
| Subject: Re: Compression issue... January 5th 2009, 12:28 pm | |
| - Nachtmensch wrote:
- dont forget to check the block for being flat.
yea you dont want the head to be warped..if you have time. take it to napa. and have they hot tank it and get it decked.. its only like $100 or so. its worth it so you get a good seal on the block. and as for the milky-ness dont drive it anymore. change out the oil like 4 times. and have it run for 5-10 mins and change it. till its golden | |
| Subject: Re: Compression issue... January 5th 2009, 12:47 pm | |
| Napa does that, i had no idea, i do want to do the ring's but im a bit pressed for time. Ive stopped driving the car as soon as i seen the milky crap, but it didnt over heat or anything so i think the head should be in good condition. | |
| Subject: Re: Compression issue... January 5th 2009, 1:12 pm | |
| Subject: Re: Compression issue... January 5th 2009, 1:45 pm | |
| My dad is starting a business down in land O'Texas, with his brother, so im going down there with him..just for a couple of weeks though, since the boy trucky is hella unemployed... | |
danstel456 Forum Frequenter
Number of posts : 241 Age : 33 Vehicle : 1992 240sx Reputation : 0
| Subject: Re: Compression issue... January 14th 2009, 1:37 pm | |
| your compression sounds ok but low on one and was the shit on the oil cap cuz if it is thata not a problem unless its in the oil then your screwed but if its just on the cap i forgot what its called but my auto teacher was talking about that a few days ago and says that its just resdue not a problem
check your oil is your dip stick milky | |
| Subject: Re: Compression issue... January 14th 2009, 3:47 pm | |
| Shit the head is already of the block, and im taking it to a machine shop so they could check the head out, if it turns out to be in good working order, im going to do the rings...and then put every thing back together... | |
RacerX Light Duty Poster
Number of posts : 104 Age : 34 Vehicle : 1990 240sx Reputation : 0
| Subject: Re: Compression issue... February 16th 2009, 10:26 pm | |
| Compression is low across the board, my SR had 165 in all 4 cylinders so it is most likely your headgasket as people have said unless you have fried rings in all 4 cylinders [god forbid lol] | |
| Subject: Re: Compression issue... February 16th 2009, 11:25 pm | |
| - RacerX wrote:
- Compression is low across the board, my SR had 165 in all 4 cylinders so it is most likely your headgasket as people have said unless you have fried rings in all 4 cylinders [god forbid lol]
thank you for your unlimited supply of knowledge. | |
| Subject: Re: Compression issue... February 16th 2009, 11:33 pm | |
HAHAHHAHAHHA. Wow dude, your a fucking piece of work. Read the entire goddamn thread before you post. | |
| Subject: Re: Compression issue... February 17th 2009, 12:02 am | |
| WTF!!! dude ur a fucking idiot!!! | |
| Subject: Re: Compression issue... February 17th 2009, 7:14 am | |
| Tell me how im a fucking idiot please Id like to know... | |
| Subject: Re: Compression issue... February 17th 2009, 7:51 am | |
| - RacerX wrote:
- Tell me how im a fucking idiot please Id like to know...
have you read the thread yet? | |
| Subject: Re: Compression issue... | |
