 starting issue
g-machine
g-machine
Number of posts : 55
Vehicle : 1993 S13 COUPE
starting issue Empty
PostSubject: starting issue   starting issue Icon_minitimeAugust 5th 2010, 11:53 am
thanks in advance for help, I did use search but got not answer. I have a ka24de and I am having problems starting it, the starter works fine but takes about 1 minute to fire up car when its cold, when its warm it takes less time.. Im wondering if its a fuel pressure regulator problem or if anyone has had a similar problem, the car runs great when it starts? thanks again...
http://www.teamselectfew.com
KappS14
Number of posts : 126
Vehicle : 91 240sx HB
PostSubject: Re: starting issue   starting issue Icon_minitimeAugust 5th 2010, 1:18 pm
did you check basic stuff like compression, wires, and plugs? Probably check fuses and fuel pump pressure and if not any of that then it could be one of your sensors like the aac or some shit. but idk, im just throwing shit out there
Number of posts : 817
PostSubject: Re: starting issue   starting issue Icon_minitimeAugust 5th 2010, 1:59 pm
I had the same problem, it turned out to be my battery. weird
PostSubject: Re: starting issue   starting issue Icon_minitimeAugust 5th 2010, 2:05 pm
when you say cold do you mean temp wise outside or the motor is "cold"?
like Tomy said, alot of starting issues related to outside temp. end up being the battery
g-machine
g-machine
PostSubject: Re: starting issue   starting issue Icon_minitimeAugust 5th 2010, 2:25 pm
im sorry what I meant was when the engine was cold.... It cranks fast it just doesnt pop off for about 45 seconds or so, but when the engine is still warm it fires right up?
PostSubject: Re: starting issue   starting issue Icon_minitimeAugust 5th 2010, 5:41 pm
did you check the plugs yet?
starting issue
» Clutch issue
» s14 electrical issue
» My clutch issue
» front end issue
» starting problems
