| so i got water in my engine | |
+6Dirty Dee Jay FusionR300zx JakeS14 D*S Dave danstel456 10 posters |
danstel456 Forum Frequenter
Number of posts : 241 Age : 33 Vehicle : 1992 240sx Reputation : 0
| Subject: so i got water in my engine December 25th 2008, 2:47 pm | |
| is there any way or any pointers to gettin it out before mt engine goes | |
| Subject: Re: so i got water in my engine December 25th 2008, 2:51 pm | |
| WUT?
how in balls did you get water in there? | |
JakeS14 Forum Frequenter
Number of posts : 486 Age : 34 Location : Chicago Vehicle : 97 240sx Reputation : -1
| Subject: Re: so i got water in my engine December 25th 2008, 6:10 pm | |
| Ok.. so did u hydro lock it or what?? | |
| Subject: Re: so i got water in my engine December 25th 2008, 8:53 pm | |
| yea how'd u do this? drain your fluids. fill em up. drain em again. fill em up. drain em again. fill em up. drain em again. do as said as many times till u think your safe? idk. | |
| Subject: Re: so i got water in my engine December 25th 2008, 9:22 pm | |
| - JakeS14 wrote:
- Ok.. so did u hydro lock it or what??
| Subject: Re: so i got water in my engine December 25th 2008, 10:06 pm | |
| Subject: Re: so i got water in my engine December 28th 2008, 3:10 pm | |
| the intake rubber boot wasn't on properly and it was like flipped open water got in it um it cranks and all but just doesn't wanna turn it started once but died and now it just cranks and sounds like its there but just doesn't turn over i work as a porter and one of the mechanics i know told me to disconnect the spark plugs and crank just to see if theirs any water and to replace the spark plugs and i just think i need to change the oil for sure but thanks for the ideas ill let ya know how it goes lol | |
| Subject: Re: so i got water in my engine December 28th 2008, 9:18 pm | |
Xmax Established Member
Number of posts : 593 Age : 42 Location : CaRoL sTrEaM Vehicle : 1993 S13 Fastback and 2006 Mazdaspeed 6 Reputation : 0
| Subject: Re: so i got water in my engine December 29th 2008, 12:29 am | |
| Your mechanic is partially right, but also pull the wire leading to the ignition coil as well. And pull your fuel pump fuse as well. Place a towel or something over the spark plug holes just to avoid any water and fuel splashing out and making a bigger mess. Do it for a good 15 to 30 seconds. Drain the oil and flush it out a few times. | |
| Subject: Re: so i got water in my engine December 29th 2008, 1:13 am | |
| umm, same shit happened to me, except i ran a funky cold pipe looking intake into my wheel well.. and when it rained. it sucked lol. but i drove my car..and it ran like dick. for about 2 blocks. parked it. and did what fusion said. changed my oil probably.. 4 times? and let it run for about 5-6 mins. and change it. and kept doing it till i saw that the oil was clear. because when i first did it it was milky. but everything has been fine. i also ran some seafoam in it for about 10 mins, and changed it on about the 3rd oil change. | |
| Subject: Re: so i got water in my engine December 30th 2008, 2:42 pm | |
| yea i would try that but it doesnt turn over well i changed the spark plugs and poured a few quarts of oil threw and let it drain so the water would just flow out then put new oil again got in the car doesnt start so now im looking either for a ka de with less miles or just find one for dirt cheap and rebuild my engine had 190000 but it ran like a champ o and im a porter at community mazda if ya really wanna know | |
| Subject: Re: so i got water in my engine December 30th 2008, 3:13 pm | |
| if you can't figure out how to remove water from your engine, I really want to see your engine rebuild. I feel its going to be awesome. | |
| Subject: Re: so i got water in my engine December 30th 2008, 4:11 pm | |
| - Jay wrote:
- if you can't figure out how to remove water from your engine, I really want to see your engine rebuild.
| Subject: Re: so i got water in my engine January 14th 2009, 1:40 pm | |
| ima try to whipe down the distributor cap i think its wet | |
splitime Forum Frequenter
Number of posts : 339 Age : 45 Vehicle : 93 miata-t Reputation : 4
| Subject: Re: so i got water in my engine January 14th 2009, 1:53 pm | |
| - danstel456 wrote:
- ima try to whipe down the distributor cap i think its wet
Spray WD40 in there. It will disperse the water. | |
| Subject: Re: so i got water in my engine January 14th 2009, 2:09 pm | |
I feel its going to be awesome. +1 on that, i'll start making the popcorn | |
| Subject: Re: so i got water in my engine June 10th 2009, 3:06 pm | |
| so i rebuilt it but just stock sort of a pain in the butt lol so if ya need any tips on anything about the rebuid let me know
only problem is i wasnt careful with the head gasket and it smokes like a chimne so i need to replace it im like 95 percent sure its the head gasket cuz oil is leaking down the block right from where the head and the block meet | |
| Subject: Re: so i got water in my engine | |
