| Building all the wrong cars | |
+70Matej JohnnyDrift David fresheg6 Vegas13 Cyclohexyl Coupe sleepyeyed240 ill roller ferrarisx D*S Homeboy. YELLOW D*S Tomy Guns danstel456 Trucky's bitch. AMD 240 blklabel44 Adrian_S13 240slider8 shiftin_sideways zero RacerX evanger drftx s14rob s13 brian Curtis DeAngelo Nelson II LeMoine gOtPUrPL3 Xmax koukimonster 240nut 007 Scuba Steve 14k s14 mrkan mikemadison_09 k c djexpo energ hs13kls JAYYS Dirty Dee Los Vlados Locos D*S Dave his180sx Mr.BackFire Jay splitime D*S Roski JakeS14 rcl1221 Nackers danielekfuj FusionR300zx SIMON timmuh SylviaFan Flicktitty ilia Stab Master Sharson DJ Longdick whiterps13 RAD MIKE Circa 3006 D*S Dstar RAMM D*S Trucky sad REVGASM Specter Nachtmensch 74 posters |
| Subject: Re: Building all the wrong cars February 19th 2010, 3:28 am | |
| Spacer spacer.
TE's are still cooler than RGII though. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 3:33 am | |
| Yeah, they will need spacers.
FRONT: 16x7.0 4x100 offset +33 REAR: 16x8.0 4x100 offset +42 (super rare in 4x100, never seen another pair in the US, only 2-3 pairs in Japan)
Later, buying 17x8 +30 (Lotus size) and moving the 16x8's up front. I got them cheaper than Advans and would not pass them up. | |
| I would like them tons better in white.
But only if you put the stickers back on after you painted them. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 3:37 am | |
| Yeah, I've been thinking of other colors, but I don't want to buy stickers... | |
| Subject: Re: Building all the wrong cars February 19th 2010, 3:46 am | |
| You have to do white. AND YOU HAVE TO put rays stickers back on. They arent concave, so you cant TELL their real TE's in pictures if their just white. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 3:59 am | |
| I was actually considering other colors. IDK yet. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 4:00 am | |
| White would be so cool on a silver car. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 4:01 am | |
| Oh, I'd also lose all the inside stickers too proving them legit. But don't Volks have castings on the inside and around the edge? It's been awhile since I've really looked at them. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 4:03 am | |
| This color would look good on silver. (darker than my paint) | |
| Subject: Re: Building all the wrong cars February 19th 2010, 4:05 am | |
| Yes, that WOULD look good. But I think white would look better. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 6:23 pm | |
| TE's are cool kevin.....but white ones like edgar said, would hit the spot. | |
his180sx Post Enthusiast
Number of posts : 1050 Age : 40 Reputation : 5
| Subject: Re: Building all the wrong cars February 19th 2010, 6:49 pm | |
| Subject: Re: Building all the wrong cars February 21st 2010, 11:50 pm | |
| as long as its at LEAST as wide as that one, and you mount the stays wider.. on the quarter panels. | |
| Subject: Re: Building all the wrong cars February 21st 2010, 11:58 pm | |
| can't mount any wider, otherwise I'm mounting on top of the tail lights. I like that width, any shorter would look goofy, and any wider would be too much with OEM aero. | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 12:14 am | |
| i'd go right with that kev, looks good to my eye, and i normally hate wings on anything | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 3:48 am | |
| working on bumpsteer corrections. Info I found out so far:
Factory outer tie rod specs:
Large Diameter Taper (Dimension B) : .59" Length (Dimension F) : 3.74" Right or Left Hand Threads : RH Rod End Thread (Dimension A) : M12 - 1.25 Small Diameter Taper (Dimension C) : .49" Stud Thread Size (Dimension E) : M12 - 1.25 Taper Length (Dimension D) : .59" Thread Type : Female
AE86 uses the same size taper (Dimensions B, C, and D). Seems like no one uses the same dimension A, most are M14x1.5. So it might be a simple matter of using AE86 parts in a different spherical end and threaded rod. Sounds much simpler than I thought. | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 6:32 am | |
| S13
Large Diameter Taper (Dimension B) : .61" Length (Dimension F) : 3.94" Right or Left Hand Threads : RH Rod End Thread (Dimension A) : M12 - 1.25 Small Diameter Taper (Dimension C) : .51" Stud Thread Size (Dimension E) : M12 - 1.25 Taper Length (Dimension D) : .63" Thread Type : Female
AE86
Large Diameter Taper (Dimension B) : .59" Length (Dimension F) : 3.31" Right or Left Hand Threads : RH Rod End Thread (Dimension A) : M14 - 1.5 Rod End Thread (Dimension E) : M12 x 1.25 Small Diameter Taper (Dimension C) : .49" Stud Thread Size (Dimension E) : M12 x 1.25 Taper Length (Dimension D) : .57" (close enough to not matter) Thread Type : Female
Looks like I can bastardize S13 ends and use 86 shanks (part that goes into the hub, no idea on technical name) | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 8:58 am | |
| Ok, stop talking about suspension geometry. Lets talk about GT wings.
GTC-300 is RAD. That is all. No need to overthink it. GET IT.
DONE.
BUT make sure you take off the APR stickers on the endplates. That looks super gross. | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 9:35 am | |
| Kevin get that wing, done deal!!! | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 9:44 am | |
| DO IT DO IT! Getting pretty excited about this car here. Cammed 2zz/TE37's/GT Wing | |
| Subject: Re: Building all the wrong cars February 22nd 2010, 4:15 pm | |
| - DS D*star wrote:
- BUT make sure you take off the APR stickers on the endplates.
That looks super gross. Exactly what I was thinking. | |
s14rob BEAR STYLE
Number of posts : 401 Age : 35 Location : manhattan, il Reputation : 1
| Subject: Re: Building all the wrong cars February 23rd 2010, 3:19 pm | |
| WHITE TE's are dope anything else is just cool | |
| Subject: Re: Building all the wrong cars February 28th 2010, 5:42 pm | |
| Valve cover has a good shape to it.
THUMBS UP FOR GOOD LOOKING VALVE COVERS. | |
| Subject: Re: Building all the wrong cars | |
