| Building all the wrong cars | |
+70Matej JohnnyDrift David fresheg6 Vegas13 Cyclohexyl Coupe sleepyeyed240 ill roller ferrarisx D*S Homeboy. YELLOW D*S Tomy Guns danstel456 Trucky's bitch. AMD 240 blklabel44 Adrian_S13 240slider8 shiftin_sideways zero RacerX evanger drftx s14rob s13 brian Curtis DeAngelo Nelson II LeMoine gOtPUrPL3 Xmax koukimonster 240nut 007 Scuba Steve 14k s14 mrkan mikemadison_09 k c djexpo energ hs13kls JAYYS Dirty Dee Los Vlados Locos D*S Dave his180sx Mr.BackFire Jay splitime D*S Roski JakeS14 rcl1221 Nackers danielekfuj FusionR300zx SIMON timmuh SylviaFan Flicktitty ilia Stab Master Sharson DJ Longdick whiterps13 RAD MIKE Circa 3006 D*S Dstar RAMM D*S Trucky sad REVGASM Specter Nachtmensch 74 posters |
| Subject: Re: Building all the wrong cars December 23rd 2009, 5:13 pm | |
| almost done collecting parts EDIT: got my throttle body too! | |
| Subject: Re: Building all the wrong cars December 28th 2009, 9:41 pm | |
| THAT SHITS POSSESED BRO CALL THE PRIEST | |
| Subject: Re: Building all the wrong cars January 15th 2010, 9:06 pm | |
| Ordered Today Hondata Intake Manifold Heat Shield Gasket - 2ZZ-GE MWR Cam Set - 2ZZ-GE - Stage 3
As soon as my valve train comes in, it is assembly time!
Running tab so far: $400 Motor $350 Misc used OEM parts $750 12/15/09 Valves, Gaskets, Oil Pump, etc $550 12/18/09 Valve springs and retainers, ARP head studs, ECU $100 12/20/09 Throttle body assembly $700 1/15/10 Cams and Hondata Gasket Total $2850 | |
| Subject: Re: Building all the wrong cars January 15th 2010, 9:16 pm | |
| Running up the credit card bill, Kevin.
I see nothing but good shit bro. | |
| Subject: Re: Building all the wrong cars January 15th 2010, 9:32 pm | |
| - Master Trucky wrote:
- Running up the credit card bill, Kevin.
I see nothing but good shit bro. Thanks man. All paid cash. No debt for me I was debating on cams vs GT wing. I figure now is a much better time to do cams than later. I can measure valve clearnace MUCH easier with the motor out of the car. GT wing will be had by the end of the year. | |
| Subject: Re: Building all the wrong cars January 15th 2010, 9:35 pm | |
| Very true. Looks can always wait.
What kind of GT wing are u looking to get?? | |
| Subject: Re: Building all the wrong cars January 15th 2010, 9:36 pm | |
| I want a Voltex, but they're hard to find used. New, they cost way too much for me at the moment. I'll probably end up with an Origin one and solid stays. | |
| Subject: Re: Building all the wrong cars January 19th 2010, 6:50 pm | |
| Subject: Re: Building all the wrong cars January 27th 2010, 10:42 am | |
| Motor assembly started Also; plan for 2010: | |
| Subject: Re: Building all the wrong cars January 27th 2010, 11:02 am | |
| ^^FUUUGH.
Cant wait to park next to it. | |
| Subject: Re: Building all the wrong cars January 27th 2010, 11:53 am | |
| Subject: Re: Building all the wrong cars January 27th 2010, 1:44 pm | |
D*S Roski DS! DS! DS!
| Subject: Re: Building all the wrong cars January 27th 2010, 11:25 pm | |
| Subject: Re: Building all the wrong cars January 27th 2010, 11:28 pm | |
| Subject: Re: Building all the wrong cars January 30th 2010, 12:13 pm | |
| Still waiting for the main bearing cap bolts and valve springs/retainers for the head. I can't do anything without either. | |
| Subject: Re: Building all the wrong cars January 30th 2010, 1:02 pm | |
| hahaha nice title. good progress. more pics of motor work would be cool. | |
| Subject: Re: Building all the wrong cars January 30th 2010, 1:07 pm | |
| When things actually sart happening, i'll get pics. Right now it's just the block girdle "installed" on the block with the crank/rods/pistons too.
I'm going to call Toyota... | |
SIMON Post Whore
| Subject: Re: Building all the wrong cars February 5th 2010, 11:58 am | |
| nice!! lookin real clean. | |
| Subject: Re: Building all the wrong cars February 6th 2010, 11:38 pm | |
| Block is assembled. Just need to put the head on, and do the timing components. Here's the sub assembly (that holds all the main bearings) sealed and placed on the block. Main bolts torqued +45° +45° New pump (and stronger gear for 9000+RPM), pickup, and baffle installed You can see the corner that cracked off, and was welded back in place in the top right of the first two pics. This is a non-structural part, and only has to seal the oil pan (which is sealed with RTV/FIPG/Hondabond anyway. This should not be an issue. You can also see a cracked thermostat housing, I have a replacement along with a new thermostat. No other cracks were detected on the block. | |
| Subject: Re: Building all the wrong cars February 7th 2010, 12:31 am | |
| Looking good looking good. Looks real clean. Very organized. nice job so far man. Good luck man. | |
| Subject: Re: Building all the wrong cars February 7th 2010, 1:13 am | |
| - Lil Baby E-Mindz wrote:
- Looking good looking good. Looks real clean. Very organized. nice job so far man. Good luck man.
Thanks, I try to keep everything very organized. It's such a pain in the ass when you have bolts and parts all over the place and not labeled! I have all my valve shims on a piece of cardboard in my room, set in a line how they came out. If these get mixed up, I'm fucked and have to measure a lot more than planned. | |
| Subject: Re: Building all the wrong cars February 15th 2010, 2:21 am | |
| HAHAHAHA, i remember when i was doing my valve stem seal on my KA, in my room my mom's was tripping!!!! | |
RacerX Light Duty Poster
Number of posts : 104 Age : 34 Vehicle : 1990 240sx Reputation : 0
| Subject: Re: Building all the wrong cars February 15th 2010, 6:10 pm | |
| Organizing all that shit is a pain but puting it all together is fun, makes me wanna build another motor.
Looks rad, props for doin somethin different. | |
| Subject: Re: Building all the wrong cars February 19th 2010, 3:26 am | |
| Bought these. Should be here in a few weeks. | |
| Subject: Re: Building all the wrong cars | |
