 timing chain issues and compresion
SEXYDRIFTER
SEXYDRIFTER
Number of posts : 247
Vehicle : 1990 nissan 240sx se hb rps13
timing chain issues and compresion Empty
PostSubject: timing chain issues and compresion   timing chain issues and compresion Icon_minitimeApril 3rd 2008, 6:09 am
cheers fellas i nned ur help need opinons , so ur help is welcomed . when i start the car there is a noud whirrr sound in the front cover in the upper timing chain section area , do u guys think it can cause timing issues firing wrong and my numbers are 150,149,149,150 . iam going to get a full tune up . should i take out the motor and buy the whole deal with the timing chain issues , o r should i worry about me self with the richness y the system is dumping too much fuel . i am going to check the maf sensor, o2 sensor, and going to put new fuel injectors-- (again)-- ,new header gaskets, get a new oil change 2 times in a row so i can clean it out with new oil an do the cleaning the system while i am at it, at advanced auto parts we sell the timing chain kit fir $455 ,even shipped comes with every thing. and fellas i need a question asked ------- if u go straight pipe with out the cat converter what so ever do u waste more gas since u dont have back presurre at all or somewhat ----? if so i have original header , to original down pipe cut in half and welded a two and a quarter inch striaght pipe to an r33 nismo muffler, if i does affect it them i should but a hi flo catco and atr topspeed they have a apex-i n1 catbat exhaust for $ 200 stainless steel . i dont know what the size of the inches are but it lok like a 2" incher or more if any one can go to top speed and verify this it would help my exhaust problems and fuel comsumption if any one knows if they can get the timing chain set for a lot cheaper let me know , cuz this saturday i am going to remove the motor. so guys wish me luck and if any help with this thread --------muchas thank youz thumb up beer
SEXYDRIFTER
SEXYDRIFTER
PostSubject: thankz fellas   timing chain issues and compresion Icon_minitimeApril 3rd 2008, 6:15 am
ohh yeah if u guys wanna help me out and do it -------------cervezaaa is on the house my b -day is this monday april-7 so beer is on me fat tire . miller lite, heineken, corona, modelo or mikes hard lemonade . or smirnoff , by the cases guys beer slap! thumb up nod/hump and do the chamba lol
PostSubject: Re: timing chain issues and compresion   timing chain issues and compresion Icon_minitimeApril 3rd 2008, 6:36 am
you shouldnt have to replace the timing chain. they are meant to last the life of the motor in most cases. and that whirring sound wont cause timing issues if it is what i think it is.
it does sound like you may need to just replace a chain guides, but i honestly stopped reading halfway though.
straight pipe will have minimal effects on mpg, if any. you may pick up a pony or two.
Number of posts : 593
PostSubject: Re: timing chain issues and compresion   timing chain issues and compresion Icon_minitimeApril 3rd 2008, 8:04 am
Try changing your fuel filter, that may cause the bad mpg. As for the "whirring" sound coming from the timing chain, Kevin is right you may just need to replace the guide. To save money first use a multimeter if your injectors are actually working and do a flow test to see if they are flowing correctly. Then go and replace them if they are not fuctioning correctly.
» timing chain
» Let's talk about my sr issues.
» door issues. help???
» ka24e loose timing chain good guides
» WTB: S13 KA24DE Valve Cover/Upper Timing Chain Cover
