 timing problem
Number of posts : 306
Vehicle : Sr'd hatch
timing problem Empty
PostSubject: timing problem   timing problem Icon_minitimeNovember 13th 2007, 12:28 pm
so im running a black top sr. and when ever i turn it on it idles high then bogs out and dies. i checked for vaccum leaks and im 100% sure the harness is fine. so im thinking that its a timing problem. does anyone have an idea on how to fix it?
http://www.myspace.com/ninjasaurusrex
profpin
profpin
Number of posts : 119
Vehicle : sil 80
PostSubject: Re: timing problem   timing problem Icon_minitimeNovember 13th 2007, 5:45 pm
usually the timing dont change unless you where messing with it.. did you always have this problem or it just started happening??
PostSubject: Re: timing problem   timing problem Icon_minitimeNovember 13th 2007, 8:56 pm
ive always had the problem. the only thing i did to "mess" with it was disconnect it once.
PostSubject: Re: timing problem   timing problem Icon_minitimeNovember 14th 2007, 6:24 pm
hmm does it run like shit under load? do your hear a misfire? I mean if your timing is fucked up and forces your car to die you should be able to hear something like a misfire
PostSubject: Re: timing problem   timing problem Icon_minitimeNovember 14th 2007, 8:42 pm
yeah i hear misfire a lot. like after i turn it on and give it a little
gas. it usually trys to die out. but when it doesnt i get misfires like
crazy. it sounds like im in nam or something
davidricardo86
davidricardo86
Number of posts : 160
Vehicle : 92 S13 SE Coupe
PostSubject: Re: timing problem   timing problem Icon_minitimeNovember 14th 2007, 11:14 pm
I'd start by making sure your ignition and fuel systems are both operating the way theyre suppose to.
Start by checking for spark at all cylinders with a spark tester you get at any car parts store. Check the coil(s) and spark plug wires. Pull out your spark plugs, re-gap them, and torque them back in with a little bit of anti seize. Check mechanical timing and ignition timing because they are not the same.
Next check the injectors to verify they are working like theyre suppose to! It would'nt be a bad idea to check the fuel regulator, hoses, and injector seals. If you have an DVOM check the injectors' resistance, voltage drop, and if possible on a scope. Check your wiring from the ecu to the sensors/actuators as well because electrical problems are really common.
Check the MAF sensor for contamination and wiring. Go towards idle control devices like tps and test them according to Nissan's FSM. Check the engine coolant temp sensor. I dont know if the SR20 is the same as the CA18 swap as far as the throttle cables go but i had to get a new cable originally out of a sohc ka24de.
Aight good luck dude! Let us know if its still messed up.
timing problem
» Timing ?
» advancing timing
» timing chain
» ka24e loose timing chain good guides
» Fuel issue or timing?? help?
