 Where is the Purge Valve and Knock Sensor located?
Number of posts : 198
Vehicle : 98 240sx
Where is the Purge Valve and Knock Sensor located? Empty
PostSubject: Where is the Purge Valve and Knock Sensor located?   Where is the Purge Valve and Knock Sensor located? Icon_minitimeSeptember 30th 2007, 4:18 pm
anyone direct me to a useful resource? thanks!!
PostSubject: Re: Where is the Purge Valve and Knock Sensor located?   Where is the Purge Valve and Knock Sensor located? Icon_minitimeSeptember 30th 2007, 6:33 pm
which purge valve? the charcole canister purge valve?
if it is the canister purge that you are talking about then it is located right on top of the canister itself
i think that on an s14 the canister is located on the drivers side engine bay by the stock airbox
now the knock is located [ON A KA24DE] under the intake mani behind the oil filter neck
it's a bitch to get to
davidricardo86
davidricardo86
Number of posts : 160
Vehicle : 92 S13 SE Coupe
PostSubject: Re: Where is the Purge Valve and Knock Sensor located?   Where is the Purge Valve and Knock Sensor located? Icon_minitimeOctober 2nd 2007, 2:43 am
Heres a picture of a ka.
Where is the Purge Valve and Knock Sensor located? CRATE_KA24DE3_Thumb
Heres from my CA.
Where is the Purge Valve and Knock Sensor located? PICT5316knocksensor2
Where is the Purge Valve and Knock Sensor located? PICT5365knocksensor
» Tranny sensor
» Blow Off Valve/Bypass Valve
» Located In Lombard
» Rod knock ka24de 50 bucks
» FS: URAS Typle 4 knock off bodykit
