| Tranny sensor | |
+3Nachtmensch Stab Master Sharson Dirty Dee 7 posters |
| Subject: Tranny sensor November 18th 2006, 8:33 pm | |
| I was replacing my slave cylinder and taking out the clutch damper box when i noticed this: is that sensor for the reverse lights? | |
| Subject: Re: Tranny sensor November 18th 2006, 11:08 pm | |
| this is more than likely a dumb question..... but have u checked 2 see if the reverse lights work? | |
| Subject: Re: Tranny sensor November 19th 2006, 12:07 am | |
| I have a while ago, and they don't work. So I am trying to put 2 and 2 together. I just found a FSM online, and it looks like it is the reverse lamp switch. go figure. | |
| Subject: Re: Tranny sensor November 19th 2006, 1:43 am | |
| dont worry, none of those sensors on the trans are plugged in on my car. no reverse lights though let me know when you figure out the reverse light wiring. id like to get mine wired up sometime... | |
| Subject: Re: Tranny sensor November 19th 2006, 2:03 am | |
| haha, the only sensor on my trans is the speed sensor. Nothing else is connected lol.
Extra pieces
5-speed swap-ftw | |
Adikt Forum Frequenter
Number of posts : 267 Age : 37 Location : Des Plaines Vehicle : Nismo 270R Knockoff Reputation : 0
| Subject: Re: Tranny sensor November 19th 2006, 3:46 am | |
| Subject: Re: Tranny sensor November 19th 2006, 4:03 am | |
| Subject: Re: Tranny sensor November 19th 2006, 12:52 pm | |
| Man, i wish that I inspected the car a shitload more thuroughly when I bought. I could have haggled the price even further. Oh well.
I will check out the wiring for the reverse light tomorrow.
BTW, how the hell do you check the relays? My horn is still not working and i know the problem is between the horns and the steering wheel, b/c both work. | |
| Subject: Re: Tranny sensor November 19th 2006, 7:38 pm | |
| could be a ground why dont you just take off your steering and hub and check it out it shouldnt be to hard to find. And worst case scenario you can bypass the relay for your horn and hardwire it if you got a switch or button for it | |
| Subject: Re: Tranny sensor November 19th 2006, 8:10 pm | |
| Subject: Re: Tranny sensor November 19th 2006, 8:34 pm | |
| i took off the steering wheel ,and the ground looks fine. I need to find out how to check relays, otherwise i will bypass it. | |
| Subject: Re: Tranny sensor November 20th 2006, 12:15 am | |
| - Atown 240 wrote:
- Adikt wrote:
- Both of you are hacks
do it right http://ka24development.com/cwilfert/S14_tranny_swap_electrical.html Yeah, reverse lights and the other useless sensors are very important. Nothing is useless, everything is there for a reason. For example did you know that the ECU changes the fuel map for when you're in 5th and neutral for better fuel economy? | |
| Subject: Re: Tranny sensor November 20th 2006, 1:00 am | |
| Subject: Re: Tranny sensor November 20th 2006, 1:16 am | |
| - Atown 240 wrote:
- auto ecu......
u doo? get a remote starter for your car!! hahaahh and u don't have to push the clutch in to start the car right? | |
| Subject: Re: Tranny sensor November 20th 2006, 1:31 am | |
| no pushing the clutch in I have a remote starter working on car and putting it in gear so it doesn't roll + remote starter and getting the car done w/ w/e ur working on= hitting a wheel barrel and almost crushing ur friend. Remote starter on a camaro z28 + cold day during winter= friend chasing car in parking lot damn we need some more smileys | |
| Subject: Re: Tranny sensor November 20th 2006, 1:55 pm | |
| auto tranny has those sensors also except they're built into the trans | |
| Subject: Re: Tranny sensor | |
| Tranny sensor | |
