| over heating | |
+8tyler D*S Dstar profpin Specter SEXYDRIFTER Nachtmensch Dirty Dee s13 joe 12 posters |
s13 joe Fucking Noob
Number of posts : 71 Age : 40 Reputation : -3
| Subject: over heating August 3rd 2007, 2:35 pm | |
| so i finally got my car up and running and i start driving at and it is over heating so i get a new thermostat and it is still over heating. does anyone have any clue on what i can do | |
| Subject: Re: over heating August 3rd 2007, 2:55 pm | |
| Subject: Re: over heating August 3rd 2007, 5:39 pm | |
| - Dirty Dee wrote:
- flush the radiator?
do that first and see if it improves. always start with the simple solutions instead of throwing parts at the problem | |
SEXYDRIFTER Forum Frequenter
Number of posts : 247 Age : 41 Location : romeoville Vehicle : 1990 nissan 240sx se hb rps13 Reputation : 0
| Subject: Re: over heating August 3rd 2007, 7:02 pm | |
| what u need is new thermostat loe temp an or water pump and flush radiator an add water wetter trust me it help alot by bringing down 20 degrees i know cuz i work for advanced auto parts | |
| Subject: Re: over heating August 3rd 2007, 7:10 pm | |
| wow you fucking suck... no offence but that's not a good place to start... throwing parts at it is a typical auto parts store solution
first off are you running a cluch fan or electric?
second off if a clutch are all your fan shrouds there, and is the duct on the bumper connected to the lower rad. support???
third off are you sure that your fan(s) [clutch of electric] are spinning at a high enough rpm
forth take a hose and SPRAYING FROM THE INSIDE OF THE ENGINE BAY OUT wash your radiator...
THEN flush your rad and make sure that it is a 50-50 mix of water and anti.
see what that does | |
| Subject: Re: over heating August 3rd 2007, 7:14 pm | |
| yeah what he said u tell em Specter | |
| Subject: Re: over heating August 3rd 2007, 7:15 pm | |
| i was talking about your post... - SEXYDRIFTER wrote:
- what u need is new thermostat loe temp an or water pump
profpin Light Duty Poster
Number of posts : 119 Age : 52 Location : southside chicago Vehicle : sil 80 Reputation : 0
| Subject: Re: over heating August 3rd 2007, 8:01 pm | |
| you should check to see if you have any air pockets in your system.. all you have to do is... when the engine is cold, take your radiator cap off, start the car, put your your control panel to heat , but dont run the fan!!, let the car run till your themostat opens (this will take some time, since you dont have any pressure in your coolant system because the cap is off), if you have an air pocket, once the thermostat opens, you will need to top the coolant off, put your radiator cap back on and your done.. | |
| Subject: Re: over heating August 3rd 2007, 8:10 pm | |
| Your user title is fucking awesome specter. | |
| Subject: Re: over heating August 4th 2007, 12:37 pm | |
| i had the same problem after replacing some parts. just needed to bleed the system as profpin stated. | |
| Subject: Re: over heating August 4th 2007, 3:41 pm | |
| yea I was gonna say are u getting hot air into the cockpit. Maybe u should just flush fill and bleed ur coolant again if u havent already as for fan it may seem like its not that but from experience granted I have an sr but as soon as that fan shutts off itll jump to an easy 210 or so so make sure that bitch is spooling | |
| Subject: Re: over heating August 4th 2007, 3:55 pm | |
| ^engrish please | |
| Subject: Re: over heating August 4th 2007, 6:25 pm | |
| aside from wat spinkter said,
Check ur clutch fan to make sure it's properly working.
Open the bleeder screw on the upper intake mani. If it's not a constant stream up fluid coming out then u have air.
If u have air leave that bleeder open till u get constant stream. | |
| Subject: Re: over heating August 6th 2007, 1:30 am | |
| thanks for the advice guys, i flushed it, it helped ALOT! not 100% yet, so im going to flush again again thanks for the help | |
k c Established Member
| Subject: Re: over heating August 6th 2007, 1:52 am | |
| i bought a funnel system, it took ALOT of air out even the itsy bitsy small pockets of air. all i had to do is put the funnel on the radiator and let the car runs for 10mins or so. and just chill | |
| Subject: Re: over heating August 6th 2007, 4:23 am | |
| - El Estrella Doridori wrote:
- Your user title is fucking awesome specter.
im the man behind the scenes... | |
drifterxxl180 Fucking Noob
Number of posts : 34 Age : 42 Location : South Holland Vehicle : 95 240sx Reputation : 0
| Subject: Re: over heating August 9th 2007, 11:05 pm | |
| OK like the original post stated cooling problem. this is what i have a Koyo Rad with daul electric fans new water pump and new nissan thermostat I've bleeded the system I've got the correct mix of coolant. not leaking any coolant and compression reads fine , i keep having to add coolant and under hard driving conditions the temp goes up and stays up whats the cause, or could it faulty gauges | |
| Subject: Re: over heating | |
| over heating | |
