 Need help..
9 posters
Need help.. Empty
PostSubject: Need help..   Need help.. Icon_minitimeJune 6th 2007, 8:42 pm
Ok guys my car has been acting super funny latelly, yesterday it was overheating and i drove it home but keeping an eye on my temp gauge but i didnt overheat, then i drove all the way home and nothing happened. So i decided to give it an oil change and then wash the engine compartment. So i did all that then i started the car, it was normal for a while and two minutes later it started to idle really bad and now it throws white smoke from the exhaust anybody have any idea what could be wrong with it.
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 6th 2007, 10:37 pm
im thinkin blown head gasket... does your oil look milky? does the smoke smell sweet?
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 6th 2007, 10:59 pm
so in other words. .
how delicious is ur car right now. . .??
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 6th 2007, 11:37 pm
No its not milky at all and the smoke smells horrible i think its the injestors....
Graduated Hipster
Graduated Hipster
Number of posts : 611
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 6th 2007, 11:51 pm
dosen have to be milky, can be a slow leak, jus rev the piss out of it. it popps it popps, fix whatever breaks
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 7th 2007, 12:20 am
Yeah it does pop and white smoke comes out....
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 7th 2007, 1:07 am
oh ok. its burning coolant somewhere....white smoke=coolant. someone correct me if im wrong.
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 7th 2007, 2:04 am
check your coolant. color should be green (or red depending on what coolant you use)
if it isnt, try flushing and filling the coolant. that may solve the overheating problem. do a compression check as well. that will tell you if its a HG.
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 7th 2007, 1:47 pm
^^ Doing that today thanks DC
Number of posts : 746
Vehicle : CTA BRO
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 8th 2007, 11:34 am
eee wtf happened.
make sure its white smoke, because white and blue are really hard to see unless you're in a dark surrounding. but that overheating issue makes me lean toward a coolant leak, = bad hg
go SR yo!
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 8th 2007, 11:02 pm
ltsPureLuck wrote:
go SR yo!
+1
Number of posts : 4345
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 9th 2007, 7:16 pm
can it be all the pw3ning u were doing?
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 9th 2007, 11:17 pm
Whats an injestor?............................. faggot.
Its because of the dents.
dents
dents
dents
dents
dents
Number of posts : 306
Vehicle : Sr'd hatch
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 10th 2007, 12:40 am
"oh ok. its burning coolant somewhere....white smoke=coolant. someone correct me if im wrong."
but cant white smoke also come from a really rich fuel mixture ?
http://www.myspace.com/ninjasaurusrex
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 10th 2007, 1:28 am
no.
black - fuel
blue - oil
white - coolant
Vehicle : CTA BRO
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 10th 2007, 1:49 am
he's right... fuel not properly burned (not much heat) will turn white
not enough air and too much fuel will turn black
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 10th 2007, 3:27 am
i have never heard of a lean mixture causing white smoke. what are your references on this?
Vehicle : CTA BRO
Need help.. Empty
PostSubject: Re: Need help..   Need help.. Icon_minitimeJune 10th 2007, 11:03 pm
it was from 3 sites, and a couple forums. it was awhile ago i would have to search for them again. but the reason was that i had white smoke coming out of my exhaust so i did some research, but in the end it ended up actually being blue smoke, so yea turbo was gone
Need help.. Empty
Need help..
