Anybody here experienced with rebuilding calipers? Just bought some 30mm irons on the cheap that are due for a quick rebuild. They're currently disassembled and I'll be blasting them this weekend. Just a few questions about the overhaul process, though:
1. What should I use to clean up the pistons/bores? Just a gentle scotchbrite pad?
2. What is recommended to lubcricate the seals when I'm putting it back together? Just standard brake fluid?
