 fs 1 full sr swap and 1 semi built long block
Number of posts : 1013
fs 1 full sr swap and 1 semi built long block Empty
PostSubject: fs 1 full sr swap and 1 semi built long block   fs 1 full sr swap and 1 semi built long block Icon_minitimeAugust 6th 2012, 1:16 am
selling these two to fund something rad i HOPE
get me at 847 890 3073 or pm me here whatever
- sr20det
- harness
- ECU
- Fresh OEM gaskets all around
- Minty fresh T-25 turbo ( bought from dsquad dave )
- Brand new Megan tubular manifold
- Brand new Megan turbo elbow
- Trust/Greddy 3inch down pipe
- Brand new circuit sports Turbo lines
- 370cc injectors 2 sets
- New coil packs
- New Brk7e NGK spark plugs
- New Touge factory Hot pipe
- Greddy style type s BOV
- Greddy LM intercooler
- Greddy intercooler piping
- Brand new Touge Factory couplers
- T-bolt clamps all around
- Apexi super suction intake
- sr20 trans
- spec stage 3 6 puck un-sprung clutch
- Brand new circuit sport oil catch can
- Stock sr20det radiator
i also have a BUILT 0 milage sr20det motor its a LONG block all it needs is a new head
( or fix the current head just one of the intake valve seats needs to be fixed the current head has 0 miles everything is checked and in spec also i did a 3 angle vavle seat job my classmate fucked one of the seats up im sure pavel can put a new seat in it for cheap )
block was built by me at school and checked by pavel
Head hasa Brian crower 264 intake and 264 exhaust cams
Brian crower valve springs and titanium retainers
Valves are cut 3 angles
block has 0 miles OEM rebuild with new bearing and ARP studs/bolts all around
Cometic head gasket
Brand new s14 water pump ( got from dabz )
all this needs are the accesories and a gasket kit from nissan ( ebay has them for like 150 for the full set )
and ill give you what ever els is laying around in my garage
you can check my build thread in here for pics of BOTH built block and the other sr swap
heres a link
https://chicagoarea240sx.editboard.com/t6428-the-car-that-will-never-run
Number of posts : 433
Vehicle : Nissan Stanza
PostSubject: Re: fs 1 full sr swap and 1 semi built long block   fs 1 full sr swap and 1 semi built long block Icon_minitimeAugust 6th 2012, 7:20 am
Please tell me you're going KA.
theboy
Number of posts : 224
PostSubject: Re: fs 1 full sr swap and 1 semi built long block   fs 1 full sr swap and 1 semi built long block Icon_minitimeAugust 6th 2012, 12:12 pm
part the harness or set on selling it all as a whole rite now?
PostSubject: Re: fs 1 full sr swap and 1 semi built long block   fs 1 full sr swap and 1 semi built long block Icon_minitimeAugust 6th 2012, 12:54 pm
Not parting anything out if it does not sell as a whole ill just run it was gamma try n pick ul crillys 1j
theboy
PostSubject: Re: fs 1 full sr swap and 1 semi built long block   fs 1 full sr swap and 1 semi built long block Icon_minitimeAugust 6th 2012, 4:45 pm
ok, cool, if you change our mind let me know
» WTB SR long block
» FS: Red top SR long block**needs rebuild** and gt2871r
» S13 ka24de long block low mileage
» WTT SR long block for nice set of wheels
» WTB sr20det full swap
