| Listen bro, listen. (SR20 halp) | |
+9hs13kls David FusionR300zx DJ Longdick D*S Trucky Adrian_S13 Nachtmensch domdaaxe58 RAD MIKE Circa 3006 13 posters |
| Subject: Listen bro, listen. (SR20 halp) May 9th 2011, 12:22 am | |
| S13 SR. Starts up fine. Then idles like sort of okay for like maybe, I dont know, like 1 minute maybe. Not even. (Note the 3 "likes") Then idles gets funky. Brass monkey. surging. Until it eventually kills itself. I can keep it running by holding the gas.then once motor gets to operating temp , I let off the gas it just dies. Doesnt try to idle or anything. Just ka-poot. Breaks up bAaAd around 4.5k under no load. Like Im hitting limiter or something. POP POP POP. You bros ask, I answer. Ciao! | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 12:24 am | |
| Almost posted this in "Off Topic" because I hate technical mumbo jumbo.
domdaaxe58 Established Member
Number of posts : 604 Age : 31 Location : Peoria IL Vehicle : Gay 350z Vert Reputation : 1
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 12:27 am | |
| Is it running super rich?
That's what it sounds like to me. Could be wrong | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 12:51 am | |
| It was. Put a different injector in because the O-ring thing was torn. Exhaust smells fine now.Is that how you tell haha. I suck at cars. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 1:52 am | |
| check the idle air control valve. unplug it, adjust the screw, etc | |
Adrian_S13 Wizard
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 2:48 am | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 3:53 am | |
| oh and for this:
"Breaks up bAaAd around 4.5k under no load. Like Im hitting limiter or something. POP POP POP."
sounds like a bad MAF | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 5:00 am | |
| Yeah that sounds like a MAF problem. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 5:46 am | |
| I'd also say check the maf. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 8:44 am | |
| yea that's def maf, i think i have a stock SR maf. give me the model #/part # or w/e and i'll check after i get off of work. u can come by and pick it up | |
David Established Member
Number of posts : 972 Age : 34 Location : hanover park Vehicle : is a work in progress Reputation : 4
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 8:48 am | |
| single cam maf's also work for this. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 10:39 am | |
| alright I'll try that. Do you think that would correlate with the whole running like shit when warm? | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 12:37 pm | |
| Are you running any tuning at all? do you have a wideband? It could be a ignition problem.
Advice needed, not teenager carboy misdirected speculation. | |
Teo Forum Frequenter
Number of posts : 433 Age : 35 Location : North IL Vehicle : Nissan Stanza Reputation : 2
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 4:32 pm | |
| We tried my maf, my coilpacks, ignitor, checked for any vacuum leaks, Ecu etc. Nothing changed. Tried my plugs and bam! Car runs. But it fouled them and wouldn't idle. No breaking up, just super rich. I'm using Ngk bkr7e, his car was originally using bk6r's... It ran and pulled hard with no problems except idle with my plugs, but anyone know why it could still be running so rich? Sorry for long rant of a post, but were out of ideas.. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 5:07 pm | |
| unbolt the fuel rail, but keep the injectors in it though. prime the car and see if the fuel is leaking out. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 5:29 pm | |
| Didn't leak when primed. Also we swapped fpr's | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 6:17 pm | |
| aftermarket FPR by any chance? or stock?
i had a aftermarket one and it would flood my shit. threw it in the garbage went back to stock. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 7:07 pm | |
| Stock ones... I'll try messing with the tps and see. That's the only thing we haven't tried.. And o2 sensors. But those don't do shit. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 8:28 pm | |
| Thanks for helping Mike, Mr. Teo guy. | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 9th 2011, 9:11 pm | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 10th 2011, 4:18 pm | |
| Im always down for helping out if I can. But it's still not working. Messed with it a little today but didn't have much time, still need to try the tps. Anyone know if coolant temp sensor or iacv could cause such a richness?? | |
Number of posts : 768 Age : 34 Location : WAY north Chi-town, Illinois Vehicle : dirty girls Reputation : 3
| Subject: Re: Listen bro, listen. (SR20 halp) May 10th 2011, 5:07 pm | |
| tps generally fks with alota shit so check that out.
iacv would just fk with your idle | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 17th 2011, 12:57 pm | |
| Went out and just messed with stuff. Tested my O2 connector with a test light in all three slots and none of them lit up. So my O2 sensor is getting no power? or is this normal? Id guess not... | |
| Subject: Re: Listen bro, listen. (SR20 halp) May 17th 2011, 4:08 pm | |
| that wont cause problems. o2 sensor pretty much does nothing. I never even had one on either of my SR's
| Subject: Re: Listen bro, listen. (SR20 halp) May 17th 2011, 4:10 pm | |
| Mine didnt have one either. | |
| Subject: Re: Listen bro, listen. (SR20 halp) | |
