| looking for a de ecu for my 92 | |
bentleyshit Light Duty Poster
Number of posts : 158 Age : 35 Location : Carpentersville Vehicle : kouki ka-t s14 Reputation : 0
| Subject: looking for a de ecu for my 92 March 19th 2011, 3:03 am | |
| im having pulsing issue on injector plug #3 been reading ppl say its need new ecu so im looking for one | |
David Established Member
Number of posts : 972 Age : 34 Location : hanover park Vehicle : is a work in progress Reputation : 4
| Subject: Re: looking for a de ecu for my 92 March 19th 2011, 8:18 am | |
robinson.erik Fucking Noob
Number of posts : 25 Age : 45 Reputation : 0
| Subject: Re: looking for a de ecu for my 92 March 20th 2011, 6:06 pm | |
| are you sure it isn't the injector? Ohm test with a voltmeter the injectors and if #3 is off from the others than that's you're problem. High mileage 240s are notorious for bad injectors over time. I've replaced 3 on my SOHC and 2 on my DOHC both with over 250K on 'em | |
| Subject: Re: looking for a de ecu for my 92 March 21st 2011, 4:08 pm | |
| there tested fine, #3 reads 10.8 ohms. if i switch injector plug 4 with 3 cylinder 3 runs fine but the 4 will have the problem, its ether the ecu or the harness that needs to be changed and right ecu will be the cheapest to do, unless someone has an engine harness for a de for grandma\'s penis cheap, | |
domdaaxe58 Established Member
Number of posts : 604 Age : 31 Location : Peoria IL Vehicle : Gay 350z Vert Reputation : 1
| Subject: Re: looking for a de ecu for my 92 March 21st 2011, 4:34 pm | |
| I have a good one. Make me an offer. | |
| Subject: Re: looking for a de ecu for my 92 March 21st 2011, 5:00 pm | |
| - bentleyshit wrote:
- there tested fine, #3 reads 10.8 ohms. if i switch injector plug 4 with 3 cylinder 3 runs fine but the 4 will have the problem, its ether the ecu or the harness that needs to be changed and right ecu will be the cheapest to do, unless someone has an engine harness for a de for grandma\'s penis cheap,
lol the ending is funny i didnt write that does this forum change ur words if u write s**t? but ur the seller i need one asap so u give me price in looking around the 50 bucks i been suspended for 2 weeks and ill be back to work today , im not trying to be broke for a month | |
| Subject: Re: looking for a de ecu for my 92 March 21st 2011, 8:13 pm | |
| $60 shipped. I'm in Peoria il so you should get it pretty damn fast. My paypal is dominicaxe58@yahoo.com if you want it. | |
| Subject: Re: looking for a de ecu for my 92 March 21st 2011, 8:30 pm | |
| ill pass now i got the problem fixed with the ecu i got | |
| Subject: Re: looking for a de ecu for my 92 March 21st 2011, 8:56 pm | |
| Subject: Re: looking for a de ecu for my 92 | |
