| How Can I Prevent This?? | |
Teo Forum Frequenter
Number of posts : 433 Age : 35 Location : North IL Vehicle : Nissan Stanza Reputation : 2
| Subject: How Can I Prevent This?? January 21st 2011, 10:07 am | |
| The lines to my catch can always freeze solid. Then when the car is started, pressure builds up causing so much blow by that it burns enough oil to smoke out half a block. I'll remove the can and free up the clog/drain the can and it will run okay. Then in the next couple days it will happen again. Is it possible that I don't have enough vacuum to pull all the vapors out of the hoses? There shouldn't be enough water in there to block the hose completely if it freezes.. And I don't like coming out to my car when it's warming up in the morning to see it in a huge cloud of smoke..
It's a redtop SR. I don't have that factory black seperator thing that goes between the T on the valve cover to the block, and on the front of the T, I have a hose going to a catch can. The outlet of the can goes to the rubber elbow thing between the MAF and the turbo. Is this right? I see a lot of SR catch cans are routed this way.
Anyone have an idea to prevent this? It gets really irritating having to mess with that shit every other day. Any help would be greatly appreciated | |
| Subject: Re: How Can I Prevent This?? January 21st 2011, 8:05 pm | |
| is your can vented to atmosphere? | |
| Subject: Re: How Can I Prevent This?? January 21st 2011, 9:36 pm | |
| No, sir. The can inlet comes from the front of the T on the valve cover. The outlet goes to the rubber elbow between the MAF and the turbo. Should be good vacuum there, I would imagine. And at wot it wouldn't be pressurized, so it should work in theory..
I used to have the can outlet vented to atmosphere, but the breather would leak oil all over the place and make a nasty mess everywhere. | |
| Subject: Re: How Can I Prevent This?? January 21st 2011, 9:42 pm | |
| should be fine set up that way
have you tried removing the catch can system to see if that is actually your problem? | |
| Subject: Re: How Can I Prevent This?? January 21st 2011, 10:01 pm | |
| that sounds all kinds of fucked up. Thats how my catch can was routed and it was fine. | |
| Subject: Re: How Can I Prevent This?? January 22nd 2011, 8:51 am | |
| Could it be that you lost compression and thats why your getting all that shit in your catch can?? | |
| Subject: Re: How Can I Prevent This?? January 22nd 2011, 10:24 am | |
| I could have lost compression.. But that would cause the can to be full of oil, right? It's usually mostly water in there. I should probably check anyway. Would a bad PCV cause problems like this?
And would eliminating the can cause any issues? | |
SIMON Post Whore
| Subject: Re: How Can I Prevent This?? January 22nd 2011, 11:01 am | |
| dun dun dunnnnnnnn
ive never heard of a problem from a catch can like that. | |
| Subject: Re: How Can I Prevent This?? January 22nd 2011, 1:32 pm | |
| Yeah same here.. I was just hoping it was connected wrong or something. Looks like I need a compression tester. And probably rings... D: | |
| Subject: Re: How Can I Prevent This?? | |
