 WEIRD
Number of posts : 3523
WEIRD Empty
PostSubject: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 12:48 am
When driving straight at about 30 mph a rumble starts that seems like its coming from the front of the car(99% positive it is).
It stops if I turn the wheels to the right or make right turn ect.
Does not stop when turned to left.
Rumbling does not increase as speed goes on.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 1:04 am
hmm
dunno
didnt you just get an alignment?
take it back there and make them fix it.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 1:05 am
It was happening before i got alignment.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 1:24 am
tires balanced properly?
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 1:26 am
Some doods mentioned that.
Would that affect it though when wheels is turned?
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 1:30 am
yes
hypothetically.
if your driver side tire is out of balance, and you turn right, weight transfers to that corner and it will vibrate.
if you turn left, weight transfers OFF of that tire, so it will seem less apparent.
I'm not sure if thats whats going on, but its something to look into.
if not, check your tie rod ends, and tension rod bushings and see if they are really fucked up.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 2:11 am
^Yes.
Tie rod ends and tension bushings for sure.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 2:13 am
if your tension rods are bad, I have a set of teins I'll let go for almost nothing.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 2:15 am
^GIVE ME.
NEED.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 2:17 am
hit me up on facebook or something
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeApril 30th 2010, 2:22 am
inner or outer tie rod
that's your problem.
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeMay 9th 2010, 9:07 pm
Ok.
Drove car on highway with this rumbling issue.
It starts at like 30sh and stops at like 55ish.
wheels misbalanced?
WEIRD Empty
PostSubject: Re: WEIRD   WEIRD Icon_minitimeMay 9th 2010, 9:08 pm
Who drives under 55?
How bad is this issue?
WEIRD Empty
WEIRD
» Weird!
