| Storage Wars | |
+58dorikin717 Gaybaby mrkan JerryCT20 boost addict energ Maikeru ka24orce Baran240 DAELEN Pharmaceuticals Forte EXE Steve VisionShift ///M3LVIN zerepdivad jdmwackness Pepe Pepe drftx LeMoine David Adrian_S13 domdaaxe58 NlineSicks240 Vegas13 Teo hs13kls revgasm_josh fresheg6 undesiredshoe whiterps13 Bliz Khalifa danstel456 Matej YELLOW ferrarisx Project240 Felix Da Housecat FusionR300zx Cyclohexyl Coupe D*S Trucky jhpark541 Stab Master Sharson SIMON his180sx Nachtmensch D*S Homeboy. Curtis DeAngelo Nelson II D*S Roski D*S Tomy Guns D*S Dave D*S Dstar borracho Los Vlados Locos evanger DJ Longdick sad RAD MIKE Circa 3006 62 posters |
| Subject: Re: Storage Wars April 24th 2012, 8:56 pm | |
| Subject: Re: Storage Wars April 24th 2012, 10:35 pm | |
| Subject: Re: Storage Wars April 24th 2012, 10:43 pm | |
| I will have a full update with pictures and shit tomorrow. Until then, stay fully torqued! | |
| Subject: Re: Storage Wars April 24th 2012, 10:46 pm | |
| If my body was an internal combustion engine of some kind, I would be the high strung kind that makes no torque whatsoever. | |
| Subject: Re: Storage Wars April 24th 2012, 10:55 pm | |
| How dare you mention your body while my pants are off. | |
| Subject: Re: Storage Wars April 25th 2012, 2:18 am | |
| Just tuck it up into your waistband. Hold it there for me, warm against your tum tum.
| Subject: Re: Storage Wars April 25th 2012, 6:51 am | |
| I would beat off next time, while I was taking a piss!! | |
| Subject: Re: Storage Wars May 13th 2012, 10:05 pm | |
| Halp! SO I put my coilovers on and shit and I went to adjust the camber to party camber mode and apparently PBMs adjust differently than Stance somehow. You cant adjust the camber when theyre bolted on, or at least it wasnt letting me, that fuck. SoI just loosened the allens upp all the way and the strut dropped off the camber plate. I wound up getting it back on and shit but now my camber plate reads this... Not even at all.. Does that affect anything? Or is it okay? I have no fucking clue how it ended up like that or anything. How can I fix that? Im think just jack the spindle and shit up enough so there is no pressure and then rotate everything straight and then tighten it down? ^ Thats what the other side reads. Pretty much even. | |
| Subject: Re: Storage Wars May 14th 2012, 8:04 pm | |
| Subject: Re: Storage Wars May 14th 2012, 8:24 pm | |
| Looks pretty even to me. Whats the problem? Yes, loosening the allen bolts will drop the top part off the camber plate.
They only go on one way, or 180 off. I'd assume they'd be in the same spot if you flipped them 180 though. | |
| Subject: Re: Storage Wars May 14th 2012, 9:10 pm | |
| Nah man look at the first picture. Then look at the "zero" line. Then look at where the bolts are in comparison and what not on each side. | |
| Subject: Re: Storage Wars May 14th 2012, 9:22 pm | |
| loosen them up, remove the bottom mount from the spindle and try rotating the whole assembly. | |
| Subject: Re: Storage Wars May 14th 2012, 9:25 pm | |
| it looked like the shock/top mount rotated just enough to skew the holes, but not enough so that you couldn't put the allen bolts back in. If you look at the picture for 2 seconds you'll realize that theres no way it can affect your alignment, so fix it if you want, but unless those allen bolts are stressed right now then you don't have to worry about anything.
sounds like someone needs to teach you how to use camber plates? | |
| Subject: Re: Storage Wars May 14th 2012, 9:29 pm | |
| Thank you | |
| Subject: Re: Storage Wars May 22nd 2012, 7:48 pm | |
| Sup baby. So last september-ish my turbo blew because I was running no BOV. I thought I would have no problem doing that because Ive seen/heard about many SRs running that way. Well not mine I guess. So I replaced the turbo with just a stock T25 because I didnt have any money to do t28. But did get an aftermarket exhaust manifold and turbo outlet. So I finished all that shit up and then didnt touch it at all after that because I started a new job at a body shop and was just busy and went into emo stage or whatever other excuse you want to think. haha. So then I just started selling shit off because I wanted to freshen the car up and do things Ive always wanted to but didnt have the income to do so before. I sold my old Stance off and picked up some Parts Shop Max coilovers. I got those cool little Godspeed Gen2 PSM replica toe arms with the bend because my old ones were hitting the subframe even at the height I was and I knew I was going to go lower so yeaaa. I got PMU D1'ers for the rad. Sold the 5zigens. Bought Roskis Work VS edition with the intentions to sell the fronts because I wanted 17/18. Copped some 18x10 -10 S1 Meisters for rears. Mismatched shit be rad. Im gonna paint the faces on the meisters silver to match alittle. Andddd now Im about to drop some bunk ass photos on yall. I hate pictures like that also so fuck you. But that's basically what my car looks like now. Rear is in the air because Im fucking around with wheel stud bullshit right now. Here comes the important stuff. Aero wise I plan on running Full URAS Type4 or possibly Works9. I have front 20mm single vents and 50mm takadashi rear overs so far. I also have a 326 wing chilling in my room so that will be on there obviously. And DMAX hood. Super flakey bright ass red paint. Candy paint drippin. FULL fucking livery. Tribal and all. HIDs everywhere. LEDs everywhere. Just like the lowest, widest, stupidest shit you've ever seen. Spider creeping down the highway. So thats it for now. I hope I never have to type that fucking much again in my life. But I had to let the thoughts in my head out because they have been stuck in there for too long. And I know yall dudes on this forum GET IT. | |
| Subject: Re: Storage Wars May 22nd 2012, 7:55 pm | |
| Inspirational cars are like the MASA LOOKS?! and ULTRA GROOVER cars. | |
Cyclohexyl Coupe Forum Frequenter
Number of posts : 294 Age : 34 Location : Kankakee Vehicle : 92 coupe Reputation : -2
| Subject: Re: Storage Wars May 22nd 2012, 8:12 pm | |
| I can dig, can't wait for finish product. | |
YELLOW Post Enthusiast
Number of posts : 1444 Age : 35 Reputation : 7
| Subject: Re: Storage Wars May 22nd 2012, 9:58 pm | |
| Wild 'N Out. Gonna make Nick Cannon look like a BITCH. | |
Bliz Khalifa Established Member
Number of posts : 886 Age : 37 Location : House of Love Reputation : 20
| Subject: Re: Storage Wars May 22nd 2012, 10:07 pm | |
| Subject: Re: Storage Wars May 22nd 2012, 10:29 pm | |
| YEAHHHHHHHHHHHH. I wanna see this thing sittin harrrrd, the erratic ass typing style in that post hits close to home as well. | |
Steve Established Member
Number of posts : 716 Age : 30 Location : Chi-burbs Vehicle : S14 & JZS161 Reputation : 4
| Subject: Re: Storage Wars May 22nd 2012, 11:37 pm | |
| That wall of words made me a little excited to see this. | |
evanger Post Enthusiast
Number of posts : 1299 Age : 31 Location : Not Chicago Vehicle : AA63, S14 Reputation : 16
| Subject: Re: Storage Wars May 23rd 2012, 10:00 am | |
| Mike, you woke up feelings I didn't know I have.
SHIII!! | |
| Subject: Re: Storage Wars May 23rd 2012, 10:43 am | |
| I dig it. Looking forward to it done. Nice work Mike. | |
ferrarisx Light Duty Poster
Number of posts : 103 Age : 35 Location : WI Reputation : 4
| Subject: Re: Storage Wars May 23rd 2012, 12:56 pm | |
| LIKE. chrome/silver vinyl livery?? EXCITE!! | |
drftx Dancing with the stars
Number of posts : 1013 Age : 35 Location : Hoffman Estates Vehicle : 90 240sx Reputation : -16
| Subject: Re: Storage Wars May 23rd 2012, 2:49 pm | |
| pretty excited to see this thing | |
| Subject: Re: Storage Wars | |
| Storage Wars | |
