| trans grinds when shifting into 2nd & 3rd | |
+2Los Vlados Locos domdaaxe58 6 posters |
domdaaxe58 Established Member
Number of posts : 604 Age : 31 Location : Peoria IL Vehicle : Gay 350z Vert Reputation : 1
| Subject: trans grinds when shifting into 2nd & 3rd January 19th 2010, 1:42 pm | |
| Ok fellas, this stared a few days ago. when I shift into 2nd and 3rd my trans will grind. So I have to put it back into neutral and very gently shift into gear. does anyone know why this is happening? My guess is a synchro or the clutch is going out??
Any help would be great. Thanks, Dominic | |
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 19th 2010, 5:55 pm | |
| Just want to add it does this until its warmed up then it stops. | |
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 19th 2010, 5:58 pm | |
| Try changing your oil. I remember reading someone on Zilvia had something similar, and that fixed it. | |
jdmj914 Forum Frequenter
Number of posts : 282 Age : 35 Location : United States Vehicle : 2WO4TY Reputation : 0
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 19th 2010, 6:51 pm | |
| I have a 5spd trans for sale in case you dont figure it out.. | |
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 19th 2010, 7:07 pm | |
| most likely synchros are starting to go | |
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 20th 2010, 9:38 pm | |
| Yea I will change the fluid asap. And I heard that if you can go through the gears easy when the car is off then your synchros are fine and it's your clutch. Is this true? | |
Fcknslo Forum Frequenter
Number of posts : 311 Age : 33 Reputation : -16
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 20th 2010, 9:47 pm | |
| if that is then thats a good guideline. hope someone can clerify | |
240slider8 Fucking Noob
Number of posts : 92 Age : 32 Location : westmont Vehicle : stock 92 s13 5 speed Reputation : 0
| Subject: Re: trans grinds when shifting into 2nd & 3rd January 21st 2010, 12:05 am | |
| i dont know about the car off thing i know that the syncros help when the car gets put into neutral while driving before switching a gear it matches the rpms of the wheels just try some syncromesh in your trans fluid it might help ive never tried it | |
| Subject: Re: trans grinds when shifting into 2nd & 3rd | |
