| Question about crank angle sensor/ CA18DET | |
Capowa Fucking Noob
Number of posts : 4 Age : 30 Reputation : 0
| Subject: Question about crank angle sensor/ CA18DET January 16th 2010, 2:52 pm | |
| On my motor the screws to actually put the crank angle sensor in they are out, and the previous owner does no know where they are. First I was wondering how to set this sensor in the correct position and where I could find replacement screws. Could this be what stops the car from starting? | |
D*S Roski DS! DS! DS!
| Subject: Re: Question about crank angle sensor/ CA18DET January 16th 2010, 4:20 pm | |
SIMON Post Whore
| Subject: Re: Question about crank angle sensor/ CA18DET January 16th 2010, 4:24 pm | |
| Subject: Re: Question about crank angle sensor/ CA18DET January 16th 2010, 5:35 pm | |
| if you don't know the answer to this question... take it to a shop before you destroy the motor | |
Capowa Fucking Noob
| Subject: Re: Question about crank angle sensor/ CA18DET January 16th 2010, 10:27 pm | |
| Um thanks? Okay what I meant was the cam sensor my bad the one in the front of the motor. http://www.180sx.co.uk/wp-content/gallery/joes-180sx/ca18det.jpgThe silver cylinder on the front side of the motor. I found the bolts and it's in now, but i'm not sure what to set it at. The car starts but then it slowly dies down like the revs start cutting off. I figured it might be I am missing the coolant temperature sensor or that I have no air filter on and the air sensor is sending a bad signal. I just got the car today so I am just trying to trouble shoot. I checked the fuel already and the pressure is at 40psi. I also checked the spark and that seems to be fine. Any help would be appreciated. | |
| Subject: Re: Question about crank angle sensor/ CA18DET January 17th 2010, 12:42 am | |
| - roski wrote:
- who IS this guy?
| Subject: Re: Question about crank angle sensor/ CA18DET January 17th 2010, 2:16 am | |
| - roski wrote:
- roski wrote:
- who IS this guy?
| Subject: Re: Question about crank angle sensor/ CA18DET January 17th 2010, 2:27 am | |
| That is the crank angle sensor (even though it reads off the cam). At least AllData calls it that. AllData says: - Quote :
- * Before removing crank angle sensor, put an aligning mark on crank angle sensor and timing belt cover.
* When installing the crank angle sensor, align marks on crank angle sensor and front cover that are marked when crank angle sensor was removed. I've never worked on one, but the crank angle sensor probably needs to be adjusted. | |
Capowa Fucking Noob
| Subject: Re: Question about crank angle sensor/ CA18DET January 17th 2010, 11:08 am | |
| Yeah I figured as much, I just don't know the correct position its supposed to be at. | |
| Subject: Re: Question about crank angle sensor/ CA18DET January 18th 2010, 12:00 am | |
| - Stab Master Arson wrote:
- roski wrote:
- roski wrote:
- who IS this guy?
Number of posts : 768 Age : 34 Location : WAY north Chi-town, Illinois Vehicle : dirty girls Reputation : 3
| Subject: Re: Question about crank angle sensor/ CA18DET January 18th 2010, 12:07 am | |
Capowa Fucking Noob
| Subject: Re: Question about crank angle sensor/ CA18DET January 18th 2010, 12:45 am | |
| Thanks for the insight I'll take this elsewhere. | |
| Subject: Re: Question about crank angle sensor/ CA18DET January 18th 2010, 1:18 am | |
- roski wrote:
- roski wrote:
- who IS this guy?
| Subject: Re: Question about crank angle sensor/ CA18DET January 18th 2010, 3:06 am | |
| - roski wrote:
- roski wrote:
- roski wrote:
- who IS this guy?
| Subject: Re: Question about crank angle sensor/ CA18DET | |
