| Heads up display question | |
+3whiteazn1184 Rated240R AChan 7 posters |
AChan Light Duty Poster
Number of posts : 103 Age : 38 Vehicle : 86 MKII Supra Reputation : 0
| Subject: Heads up display question January 30th 2007, 5:18 pm | |
| This is probably a dumb question...But my HUD takes a long time to turn on when it's really cold out. Is that normal? | |
| Subject: Re: Heads up display question January 30th 2007, 6:11 pm | |
| Every thing slows down in the cold (including me)! lol!! | |
Number of posts : 582 Age : 40 Location : chicago, il Vehicle : 02 Subaru Wagon Reputation : 0
| Subject: Re: Heads up display question January 30th 2007, 11:16 pm | |
| lol... yea thats true... especially u angelo... lazy... | |
| Subject: Re: Heads up display question January 30th 2007, 11:42 pm | |
| yes that is normal because the capacitor is usually crap and needs time regardless kick it and get an analog huds blow my load | |
| Subject: Re: Heads up display question January 31st 2007, 7:42 pm | |
| Yeah I know stuff slows down in the cold, but I didn't think this would happen for a HUD. I guess I was wrong.
Hmmm...Wutangben on ClubFR says I could sell my HUD for like $250 or something. If that's the case, I should probably do that. | |
| Subject: Re: Heads up display question January 31st 2007, 7:55 pm | |
| Do it! If ya need an analog I've got one for cheap!! | |
| Subject: Re: Heads up display question January 31st 2007, 9:34 pm | |
| mine never did that....
starts right up | |
| Subject: Re: Heads up display question January 31st 2007, 9:49 pm | |
| - dc2_lsvtec wrote:
- mine never did that....
starts right up See? Why isn't mine like that??? | |
| Subject: Re: Heads up display question January 31st 2007, 10:29 pm | |
| Mine did it too. Some consider it to be early signs that its gonna crap out on ya.
If it helps, mine worked awesome for 2 years then it started to just get a little chilly and it would do that. 2 weeks later it went out almost compleatly only turning on when it wanted to. | |
| Subject: Re: Heads up display question January 31st 2007, 10:33 pm | |
| i have a spare HUD module. the one that projects the numbers on the window.
PM me if you want it | |
| Subject: Re: Heads up display question February 1st 2007, 12:37 am | |
| Is it possible that it's a wiring thing? | |
| Subject: Re: Heads up display question February 1st 2007, 1:21 am | |
| i believe it is the unit itself that goes out. doesnt hurt to check the wiring though. give it a try. | |
| Subject: Re: Heads up display question February 1st 2007, 10:43 am | |
| My first HUD stopped working because the unit inside the cluster went bad. It has been said that there is a white box at the driver kick panel that controls the unit, but I haven't ever heard anybody confirm that's what it is. The unit that displays the speed on the windscreen is just a display. It recieves the information from the unit inside the cluster so with that being said, if your cluster doesn't work, the HUD will not work either. If your cluster is still working, you probably need a new HUD... otherwise just get a diffrent cluster (analog preferrably) so you don't have this problem again. On a side note, when the cluster unit is not working, the dash lights 9/10 times don't work either. | |
| Subject: Re: Heads up display question February 1st 2007, 9:51 pm | |
| From what ive heard its this little capacitor thing usually if you have any soldering skills it can be fixed its just time consuming with stripping the dash theres a write up somewhere ill try n get you a link | |
| Subject: Re: Heads up display question February 1st 2007, 11:34 pm | |
| Getting the cluster out is pretty easy... just a lot of bolts to take out. If your lucky you can just drop the wheel to the lowest setting and take the 2 screws out of the bezel and take all the buttons out and gently pull it out. Unfortunatly, a lot of times they break or crack when you do it. Its better to take the door sil, kick panel, under dash panel, steering wheel cover all off, take the 2 bolts closest to the wheel out and drop the other 2 down nearly all the way, then continue with the above.
With the capacitor mumbo jumbo... its much easier to just get a new cluster for 80 bucks. But if your an electronics guru, you could probably make some good money repairing these and selling them with core charge. | |
| Subject: Re: Heads up display question February 1st 2007, 11:47 pm | |
| these HUD units are pre LED days meaning that they are lit up by a cold cathode ray tube [much like your tv, only a little different]
if that unit goes out bye bye HUD. that is most likely what is happening because when these get old they don't fire up all the way when they are turned on and take a while to power up all the way...
basically you are going to need a new one sooner or later | |
| Subject: Re: Heads up display question February 2nd 2007, 4:07 pm | |
| This is probably ridiculous, but is there any chance I can get replacement cold cathode ray tubes from anywhere? | |
| Subject: Re: Heads up display question February 3rd 2007, 4:23 am | |
| I also notice that all of my other gauges don't light up until the HUD warms up. Did this happen to anyone? | |
| Subject: Re: Heads up display question February 3rd 2007, 9:28 am | |
| - AChan wrote:
- I also notice that all of my other gauges don't light up until the HUD warms up. Did this happen to anyone?
Read my boy...Read! Lol! Pay attention to the last sentence.... - Nackers wrote:
- My first HUD stopped working because the unit inside the cluster went bad. It has been said that there is a white box at the driver kick panel that controls the unit, but I haven't ever heard anybody confirm that's what it is. The unit that displays the speed on the windscreen is just a display. It recieves the information from the unit inside the cluster so with that being said, if your cluster doesn't work, the HUD will not work either. If your cluster is still working, you probably need a new HUD... otherwise just get a diffrent cluster (analog preferrably) so you don't have this problem again. On a side note, when the cluster unit is not working, the dash lights 9/10 times don't work either.
| Subject: Re: Heads up display question February 3rd 2007, 7:41 pm | |
| Sorry...I'm not good at English. | |
| Subject: Re: Heads up display question | |
